Thread: hole in liner
    SOUTHREN VIRGINIA
    31
    hole in liner
    there is a small hole in our liner and outside wall though ive made sure there are no sharp edges on the poolside i cant seem to get a patch to go on properly after applying the glue to the patch and pulling it apart underwater it just doesnt adhere properly ive cleaned up the surrounding area with a abrasive pad and sponge.also now iam starting to see what i believe to be rust from the inside wall making sharp points toward the liner,the pool is only 5 years old,any ideas??
    a/g 24'round 4' app 13500 gal sand filter 16''hayward (100lbs sand)1hp single speed pump on timer 12 on 12 off day &night and i use the bbb maintaince
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    What kind of glue are you using? They all set quickly, but some set so quickly that underwater patching is almost impossible. Boxer #100 is supposed to set a little slower to let you get the job done under water.
    Not sure how to advise you on the rust. To do anything about it, you'll have to drain the pool and pull the liner, which will probably require a new liner anyway, but if you let it go, you might need a new pool.
    SOUTHREN VIRGINIA
    31
    pool liner patch
    the glue comes from a pool store patch kit-where would you find boxer glue ? sure would like to try that as i think thats my problem ,it just sets up to fast.as far as the rust i was afraid that would be the answer id get,guess i wanted to tell me it was probaly just mineral deposits and not to worry about it.. iam gonna try to for go changing the liner till next season,hopefully itll make it through the summer.as we live in a rural area it would sure put a strain on my well.thanks
    SW Indiana
    9,199
