Results 1 to 10 of 10
Thread: Recently Re-Plastered; pits, cracks, and lines already?
    We have owned a pool for two months - it was re-plastered just before we took ownership. Today, I noticed a few cracks around the "bench" in our built-in hot tub. I was losing daylight as I investigated and, upon turning on the main pool lights, I saw mild pitting and plenty of lines/slightly uneven marks along the bottom of the pool. I posted a photo although I'm not sure how visible it all is in there.
    On a scale of 1-10, is this fairly typical, a matter of concern, or a major problem?
    IMG_2890 by DC Orbiters, on Flickr
    Fairfax, VA - 25,000 Gallon IG Plaster with a Sand Filter
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Recently Re-Plastered; pits, cracks, and lines already?
    Very clear water... However that looks like a pretty rough plaster job! Can we get better pics of the cracks?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Yes - they appear along the bench seat:
    001 by DC Orbiters, on Flickr
    In daylight, the pitting and lines in the main pool are not noticeable. We just haven't used it at night when the lights show the imperfections so clearly.
    Jul 2011
    Arizona & California
    805
    I think you should call and notify the plastering contractor on this job. The cracking I see is not good, and the plaster lines indicate poor troweling technique.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Wow that is checking, and _WILL_ de-laminate, its just a matter of time. I really dont mean to offend, but that is an awful plaster job. Just look at the corner in your 1st picture. Its just slapped on there.
    I did send photos to the prime contractor - he said the cracks are common at this stage of curing and should disappear - and imperfections in the plaster are normal. The work was subcontracted out to a company that, I'm told, does most of the re-plastering work around here. With the lights out, it definitely looks more than a little imperfect - it just doesn't look like something that is supposed to last over a decade.
    Jul 2011
    805
    Lershac is right about the possibility of delamination, but it is hard to know for sure. But that cracking is far beyond normal and will not disappear. Your PB is wrong in what he told you.
    Yes, some minor plaster imperfections are normal and unavoidable, but in this case, it appears from the pictures that they are far worse than normal, and simply indicate poor workmanship quality. Looks like a "rush" job.
    I referred the prime contractor to this thread - he's since been in contact with the sub to come back and have a look.
    The subcontractor reviewed the work today and agreed, at least, there should be no cracks so soon after the work - he said they're planning to send out a diver (which sounds very dramatic).
    Jul 2011
    805
    A diver can sand the troweling lines and rough areas, but I doubt the cracks can be fixed.
