Results 1 to 19 of 19
Thread: My funky journey to getting my pool right.
    Jul 2012
    Cedarhurst, NY
    16
    I've been lurking around for a week, finally got my kit and did some tests.
    (I had a big problem with low PH and soda ash which forced me to drain my pool by half/.vacuum/refill/vacuum.)
    I eliminated the Soda Ash fiasco and restarted getting my pool's chemistry right.
    Test this morning and got these results...
    pool (42000 gallon, in ground)
    CL = 7
    PH = 7.2
    TA = 70
    ch = 120
    cya = 50
    cool, but pool kinda green...algae?
    Went to the pool calculator and boom..it says shock = 4.3 jugs of 182 oz bleach...
    I added 4x182 oz jugs of bleach, brushed the walls and floor and am now running the filter.
    The 10ml CL test after adding bleach took 58 drops! So I guess it' s friggin' shocked all right.
    I mean a cl = 29 shocked the **** out of me!
    I got curious about the measurements (seemed high) so I actually measured the deep end of my pool (original owner who installed it said tit was 10 feet deep at the deep end...
    Lo and Behold it measured 9 feet... so the calculations in the Pool Calculator are all wroong!
    Which means the pool is 38,900 gal instead of 42,900...just great. But the calculator still says 4 x182oz to raise CL from 7 to 16...
    Any idea of why the crazy difference?
    I plan on running the pump/filter overnight, while I await further instructions.
    Thanks!
    Craig
    Craig Ramseur
    27600 gallon IG pool
    Hayward S244T sand filter
    Hayward Super II 3/4 HP pump
    Taylor TF100 Test Kit
    Aug 2008
    Fredericksburg, VA
    51
    Re: My funky journey to getting my pool right.
    You're on the right track. For a CYA of 50, you should get FC down to 20 for shock level and keep it there until water is clear, you don't have a drop of more than 1 PPM of FC overnight, and CC is 0.5 or less. Once you've hit all three of those conditions, you can let FC drop down to normal levels (around 4-6). Keep brushing the pool regularly during shock.
    20,000 gal. free-form plaster on concrete
    Triton DE filter, 1.5HP pump
    Aquabot Elite pool cleaner
    Pointyhead's Avatar
    May 2012
    Central Georgia
    113
    And I'll add that it might take a week or more for the water to clear completely, but it will. I was all panicky about my water not clearing up, but after a week it is now sparkling clear! These guys know their process.
    10 year old 18x32 inground, vinyl liner 1 year old, 25,000 gallon Grecian, Hayward ST244 Sand Filter, 1hp Hayward pump, Diving board, Side Steps, Koolcrete decking located in middle [s:37hekvij]earth[/s:37hekvij] Georgia.
    22,553
    Four thousand gallons isn't a lot and about half a large jug would be plenty to make up the difference.
    I also bet that your pool isn't as big volume wise as you think it is.
    Jul 2012
    Cedarhurst, NY
    16
    Got up this morning did the testing:
    FC = 26.5
    CC = 1
    Copper = 1.0
    PH = 8.2
    Also, "Bama Rambler" - you are right . I found the original specs from the builder (1985) and it is actually 18 X 36 which means 31,500 gallons.
    How do I get the CH down to about 20? Wait?
    Later today I'll brush, and check my filter sand for channeling.
    I've read many of the stories here, and already trust the process.
    I just want to make sure my figures don't need some extra addressing.
    (Like my PH level going up 1 point in 12 hours overnight).
    Oh, and the filter is supposed to run 24/7 during the process, right?
    Thanks! Craig
    Craig Ramseur
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by cram
    FC = 26.5
    CC = 1
    Copper = 1.0
    PH 8.2
    CH normally = Calcium Hardness but from context I assume you mean Free Chlorine (FC). If that assumption is correct - yes, you wait. Sunlight will knock off a lot of FC in a hurry. The higher you start the larger the % drop.
    pH can't be measured accurately at FC > 10. Don't bother testing it until you are past the shocking phase.
    Filter 24/7 is correct.
    22,553
    With a cya of 50 it should be down there in a day.
    Jul 2012
    Cedarhurst, NY
    16
    Cool...thanks.
    new numbers Sunday, Aug 5 @ 12:40pm EDT:
    FC = 28.5
    CC = 0
    CYA = 50
    Also, no problem with stopping the filter to check for channeling? and dealing with that for 30-60 mins or so?
    The filter pressure has't risen (stuck on 18 since yesterdays backwash before shocking).
    Here are pictures of the deep end:
    Craig Ramseur
    22,553
    No problem stopping the pump for a little while.
    Jul 2012
    Cedarhurst, NY
    16
    this morning...
    FC = 21
    cc = 0.5
    I can see the dead algae collecting. Nice.
    I'll retest, then vac/brush after work.
    Craig Ramseur
    Jul 2012
    Cedarhurst, NY
    16
    1141 pm
    after vacuuming to waste, and adding water to replace the pumped out water:
    FC = 21
    CC = 0
    not dropping so quickly. but pool definitely clearer.
    Craig Ramseur
    22,553
    As you kill the algae you should notice the FC holding longer and longer.
    Sounds like you're well on your way.
    Jul 2012
    Cedarhurst, NY
    16
    Update... used some POP for a few days...pool reacting ncely.
    Right now pool looks BEAUTIFUL. numbers are stable except for FC...It has RISEN since yesterday.
    on 8/10 test 8:29am:
    FC=17
    CC = .5
    PH =7.2
    On 8/10 test - 6:25pm:
    FC=15.5
    CC= .5
    PH= 7.2
    8/10 - 9:01pm (after dark)
    FC= 14
    CC = .5
    8/11 - 10:00 am:
    FC = 17.5
    cc = .5
    TA=70
    PH = 7.2
    What would cause the FC to rise overnight?
    The only thing I did was vacuum (to waste) after the 6:25 test, then replace the missing water with fresh fill.
    Craig Ramseur
    Jul 2012
    Cedarhurst, NY
    16
    8/11/12 - today's evening test results:
    FC = 13
    CC = 1
    PH= 7.2
    TA = 70
    According to the pool calculator
    To raise my PH from 7.2 to 7.5, I need to add - 76oz of Borax
    and to raise my TA from 70 to 80, I need to add - 4lbs 10oz of Baking Soda
    But the water look so clear and sparkly now, I'm afraid to cloud it up again.
    Are my current numbers (shown in the post above) okay or should I make the adjustments?
    Thanks for all the help!! ...new pics will post tomorrow.
    Craig
    Craig Ramseur
    Sep 2009
    Greentown, IN
    914
    You're FC will never raise without the addition of more chlorine. Did you add more chlorine just before your after dark testing on 8/10? I would say that or a testing error... it can happen, even at home.
    I wouldn't mess with ph until your fc gets down into normal range for your pool... Check the pool calculator for that. If your chlorine is high, it can throw off your ph test.
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jun 2012
    Mint Hill, NC
    2,589
    I think you are not done shocking yet. You still have 1ppm CC and no OCLT that is valid since FC can't go up w/o error. It could be that your night test was too soon after adding the bleach and the sample was weaker than the true FC or you may have had a testing error.
    Don't slip up now - keep the POP.
    Jul 2012
    Cedarhurst, NY
    16
    Okay. Don't mess with PH until FC is in the normal range - got it.
    User error is a distinct possibility. I have not added ANY chlorine since the 8/10/12 night test.
    This morning's numbers (8/12/12)
    FC =14.5 (note this is up again from last night's test which was FC =13)
    CC = 0
    as an aside with the TA test, how red should it turn?
    at 7 drops it was a stable dull, then 1 more drop and it was full flaming hot pink.
    so am I at 70 or 80? - Or should I not worry about this until the FC is normal? <wink>.
    The pool looks better that it has ever looked in the 13 years I have had it! The water is absolutely beautiful.
    Craig Ramseur
    Jul 2012
    Cedarhurst, NY
    16
    Re: My funky journey to getting my pool right. - updated pic
    pictures as promised (After one week of BBB and TFP):
    Craig Ramseur
    Jun 2012
    Mint Hill, NC
    2,589
    NICE!
