Thread: Just how bad is it to use morton rust remover salt?
    I have a saltwater system running on my intex quickset pool.
    I bought it because I have an iron clearwater pump running my solar heater and I thought it might reduce internal rust in the pump.
    But just how bad is this sutff?
    Is it unhealthy?
    My build spec: Omaha, NE: 20X46, Galvanized Steel Walls, Tan (Sandstone) Vinyl 20 mil Liner, SWG/Intellicholr, 2 Intellibrites Color Lights, 3 Laminars, Intelliflo Variable Speed Pump, Sand 30" Filter, Boulder Springs Diving Board, Pentair Easytouch, Autofill, Heater 400,000 BTU propane, Coverlogix 9000M Safety Cover, All Color rails/accessories (Coppervein from inter-fab).
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Just how bad is it to use morton rust remover salt?
    They add a little citric acid to the salt. Won't do anything for your pump.
