Thread: Coverstar Swaping Motor ends and reversing clutch direction
    I recently moved a pool that had a coverstar system on it that i hadnt seen work. In the move we decided to reconfigure the coverstar set up by switching the motor end from a left hand to a right hand mount. initially this didn't seem too difficult , the motor mechanism seemed to fix on either end, and the pulleys could be flipped to the other side of the mechanism. Only problem is that now its finished ive realised the system seems to work with some type of clutch that means the tube still spins the same way as I am assuming before. i.e now the cover is being pulled under the tube rathern than over it. Does anyone know if the clutch system can be reconfigured so it works in the opposite way ? trying to describe this wasn't too easy so there is a picture below
    Nov 2011
    Moberly,MO
    1,010
    Re: Coverstar Swaping Motor ends and reversing clutch direct
    No, you will have to buy a new assembly on the drive end. I am going thru the same issues on a customers pool. They changed their mind as to where they wanted the drive.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Yeah I think I have it figured out now, looks like there is a gear assembly and I need to replace the three dogs.
