Thread: Salt generator readings accurate?
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    I have an aqua rite pro with a T9 cell on my pool and I was curious as to how accurate the salt reading are. I am waiting for some new refills for my test kit so I went to the pool store for a test. They reported a salt level of 5200 ppm while I am showing 3500.
    19000 gallon inground fiberglass pool
    Hayward Pro Series Sand filter S244T 62 gal/min
    Whisper Flow WFE-2 / 011511 1/2 hspr pump
    Aqua Rite AQR Pro SWG, T15 cell for 25000 gal
    38,294
    Re: Salt generator readings accurate?
    How old is the cell? One sign of it going bad is reading low salt levels.
    If you keep it happy, it will keep generating, but you may end up with high salt levels when you do eventually have to replace the cell.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    fordsbyjay's Avatar
    Sep 2009
    Lafayette, LA
    64
    It is about 3 years old IIRC. I did have to clean it out today due to a bunch of scaling. I work out of town a lot so it has been getting neglected. The downside to saltwater is it is so maintenance free that you get lazy on the regular checks. It is spiffy clean now so I will have to see how it works. Is there a machine to test them at the pool place?
    38,294
    they do have a system to test the cell, but I am not really sure what it actually tests. Might just be whether it functions at all, and not take into account reduced performance.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Seems like it should be pretty easy to invert a cup of some sort then put it in front of a return and grab the water straight from the pipe. If FC is higher than the pool, it must be working.
