Thread: Adding 12.5 % shock right now.. quick question?
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    I just started with BBB yesturday and my K-2006 is not here yet.
    I just did a OTO test with 2 different kits
    FC .5 with Leslies
    FC 1 with HTH
    I added alot of water early this morning because I had to vac to waste today.. (pool is now ALOT clearer)
    It is very sunny here right now and I know it is best to add chemicals at night but should I add the 1 quart 3 cups 2 oz that the pool calulator suggested right now?
    We would like to get in the pool soon but I dont want the FC to drop anymore
    If I add now.. how long do we have to wait to swim?
    14500k inground, vinyl, built in 2007
    Hayward Sand Filter, 1hp Hayward pump, AquaCal electric heat pump
    Taylor K 2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: Adding 12.5 % shock right now.. quick question?
    Add it now, give it 15 minutes or so to mix, and jump in. You'll mix it better than the pump.
    ajackson's Avatar
    Jul 2012
    Central Ohio
    76
    Great.. thanks for the speedy reply.
    Taylor K 2006
