Thread: solar panel temp sensor malfunction
    Feb 2011
    Petaluma, Ca
    665
    When I checked the temp of the solar panels the reading was 255 deg in the morning, later in the day it was reading 10 deg. The pool people said the sensor was bad, $60.00 later with a new sensor the readings were close to the same 255 deg in the am, then 30 deg when I looked after work. This is an easy touch 8 controller. It has worked fine since 8-11 when it was installed. Any ideas whats up?
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Feb 2011
    Petaluma, Ca
    665
    Re: solar panel temp sensor
    It's back to 255 deg as of 9am.
    Feb 2011
    Petaluma, Ca
    665
    Re: solar panel temp sensor malfunction
    Gopher chewed through the wire! I should have known with all the problems those xxx cause me in this sandy soil. Back to normal at the moment but I think I'll get a conduit for the future.
