Thread: What is sodium bisulfate ?
    May 2012
    Northern Connecticut
    103
    Very new to this and I'm trying to lower my ph. My husband bought this what is it? I couldnt find it on the pool calculator. Will it work or should I just get baking soda.
    Thanks
    Sandy
    24,000 20x42 double roman end in ground pool being built. Start date june13, 2012.
    Finished July 4th, 2012, sports pool, vinyl,SWG, DE filter, fountains. Heat pump,
    First Pool Ever!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: What is sodium bisulfate ?
    Dry acid and yes it is used to lower the pH.
    You would not use baking soda to lower pH. Use baking soda to raise TA.
    You're done SLAMing when:
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Most people on here would recommend muriatic acid to lower pH because the sodium bisulfate addes sulfites to the water which can damage concrete over time.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
