Thread: Vacumm for Intex pool
    The vacuum that came with our pool will not pick up any sediment due to that fact that we have to hook up the hose and everything is sucked through a net. What are you guys using to keep your pool clean and do you have any recs on a new vacuum?
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    Re: Vacumm for Intex pool
    You can get a hose and a vacuum head, which can be attached to the suction side inside the intex pool or even to the skimmer itself (there's a part for that, but Intex is probably out of stock). Then you can vacuum with the pump/filter. But the fines might pass right through a standard intex filter (spun fiber) anyway.
    Prior to getting a real vacuum (as noted above) we used this http://www.amazon.com/Water-Tech-BROOM- ... B0015UCRXM very happily (with a thick opaque toddler stocking inside). I still use it now and again cuz the real vacuum is more of a PITA to hook up and mess with. For leaves, you can tuck the flap on the inside in so it sucks them up better. It works well, but the footprint is not very wide so it takes more passes to get all the floor dirt.
    The above link to Amazon has a nice deal on this vac for $35. I'm pretty sure it's normally $99.
    I've heard good stuff about some other vacuums too. Catfish rings a bell...
    The hose vacuum is just terrible. Not only do fines pass through, it adds water to the pool, messing with chemistry. Blech!
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    I use this with my 2650 gph Intex filter system. Works like a champ!
    http://www.amazon.com/gp/product/B0007P ... 02_s00_i03
    18' x 48" Intex Ultra Frame
    2650 Intex Sand Filter
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    Quote Originally Posted by noresull
    I use this one as well, I love it. Just wish I had the bigger pump!
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
