Thread: Aquarite SWG no power
    East Tennessee
    2
    Need help with Aquarite system (1 year old). Replaced ICL (AS32-2R025), standard item from digikey. Original was cracked and fell apart when touched. Plugged in, and immediately blue main 20A fuse. Possible problems? Poor soldering job (first time)?
    The standard ICL of other threads is the SL32. IT has the .024Ohm resistance at current wher the AS (Amertherm) is .0185Ohm. Also, larger tolerance of 25% as compared to 15%.
    The Amertherm was what was in the board.
    Thanks.
    18x36 IG vinyl with Hayward sand filter, pump and Aqua Rite SWG with T15 cell.
    22,548
    Re: Aquarite SWG no power
    Welcome to TFP.
    I'd check your soldering, but I suspect it's something else shorted.
    East Tennessee
    2
    Thanks for the idea.
    It ended up being a mis-connection of two wires/leads; black-red on top right of PCB. Fortunately, no damage - way to go fuse.
    Working great now.
    22,548
    Glad you found it & no damage was done.
