Results 1 to 16 of 16
Thread: New leak at filter multi-valve
    LauleaHere&There's Avatar
    Aug 2010
    Rural Moloka'i, Hawai'i
    155
    Could you guys help me diagnose? I just replumbed my system to include a solar heater, and took the opportunity to look inside my zeosand filter, rinse, etc. Now it's leaking from under the top where the valve handle is. Does this sound familiar to anybody? What should I look for?
    12' round above ground pool. 3,500 gal. Vinyl liner. Waterway Supreme Hi-Flo 48 frame pump. 1.5 hp. SWG. Sand filter with Zeobrite.
    Thanks, members of Trouble Free Pool, for being so friendly and informative!
    Aug 2010
    155
    Re: New leak at filter multi-valve
    Photo:
    38,520
    Did you open up the valve while you were cleaning everything?
    I think the water can only get up where you are pointing to if there is something wrong with the spider gasket inside ... although then I would expect you to see water out the waste as well.
    Aug 2010
    155
    Thanks for answering, Jason. I only took the valve assembly off the tank, I didn't take it apart. And I am not getting leakage from the waste port. The big O-ring at the base of the valve assembly is in good shape. I lubed it good when I put the whole thing together a couple of years ago, and lubed it again before I reassembled the filter. I did notice a couple of things--when I turned on the pump, the valve assembly hissed a little; the inside column of pipe that covers the center pipe that leads to the laterals has rough edges; and the water that came out of the filter when I turned the pump on was cloudy. Does that help? Thanks!
    Renee
    Aug 2010
    155
    Also, if I chose to replace the whole valve assembly, how can I tell if what I buy will fit my sand tank?
    38,520
    Well before you consider replacing it, I would certainly just open it up and see if something is obviously wrong inside. If it is like mine for the DE filter, there should just be about 8 bolts to remove to open up the top and try to see where the water is coming from.
    Posted from my Droid with Tapatalk ... sorry if my response is short
    Aug 2010
    155
    Unfortunately, mine doesn't have bolts--I don't see an obvious way to get the top off.
    38,520
    hmm. Well that kind of stumps me since if have not worked with the top mounted valves.
    Hopefully someone else may have some thoughts.
    Aug 2010
    155
    Thanks anyway, Jason. Much appreciated!
    22,553
    What's the model number on the valve?
    I think it's twistlock and there's a lock pin you have to pull so you can turn it.
    Aug 2010
    155
    Bama, if there is a model number, I sure can't find it. There is a COD on the tank: 21786A. Both valve and tank are from Advantage Mfg, but I'm pretty sure that the valve is compatible with a Hayward 711 or 714T. Where would the pin be if there was one?
    22,553
    I can't tell but that white piece sticking out the side of the cap might be it.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    if it leaking from the arrow then it's SPX0714L COVER O-RING
    keep in mind you need to tighten these lids like a car tire. a little on each bolt on opposite sides until tight.
    if it's leaking directly from the handle then its O-RING SHAFT SEAL ASSY SP0714T,SPX0735GA O-Ring & Backup Ring
    this is all assuming it's truly comparable with the spx0714
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Aug 2010
    155
    Kevin, thanks! I tried mounting the assembly again, being careful to tighten as you described. Wow! no leak at the arrow, but a teeny one at the collar. Still tentative about opening up the top, as that white "pin" seems to be pretty permanently installed. I don't want to pry it off with brute force and bust it up.
    I'm going to let the pump run for a few hours, and tomorrow I'll disconnect and try again with the valve assembly. Thanks so much for your help.
    May 2011
    Baton Rouge, LA
    33
    Thanks for this post and thread. My Waterway multiport was leaking out the backwash port when I filled and opened this summer. So I took it apart expecting to see a problem with the spider gasket. The gasket was fine but the diverter valve was sticking in up position and just letting water blow by. I lubricated the o-rings and moving parts and put it back together and am happy that it is now working fine.
    IG SW Gunite, 15K Gals, Intelliflo pump with cartridge filter
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Advantage Manufacturing has a website at http://www.advantageman.com
    They don't list manuals and I don't see a filter with the exact same multiport valve but you may want to check with them to help identify what you have and possibly get a copy of the manuals for your equipment.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
