Thread: Pool will be replastered soon. When to install a new SWG?
    Jul 2012
    Austin, TX
    75
    Hi all,
    My pool will be replastered soon. I am redoing some of plumbing and planning to add a new SWG. Just wonder if I should wait for a couple of weeks to install the salt cell after the pool is filled. I am concerned about the large amount of loose plaster powder and other loose debris in the new water that may damage or shorten the life of the cell. Any thoughts on that? Please advise. Thanks.
    Scott
    Lazy-L shaped pool and a spa. 22.5k gallons. Pentair VS pump. Pentair cartridge filter CCP520. STA-Rite SR400NA heater (400K BTU). Leuder limestone coping. Pebble sheen (blue granite) Wooden deck.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Pool will be replastered soon. When to install a new SW
    When you start up new plaster and you have a SWG, you do NOT add salt, or turn on the SWG, until 30 days after the plaster has been applied.
    See article in Pool Schole Re: new plaster start up here: pool-school/pool_plaster_start-up
    Also, National Plasterers' Council Start-up Card is here: http://www.npconline.org/assets/documen ... UpCard.pdf
    You're done SLAMing when:
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    No large particulates will be making it past your filter, and the SWG will not be generating chlorine. Have it installed during the re-plaster. Start up 4 weeks after.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
