Thread: tf100 test kit
    tf100 test kit
    does the tf 100 test kit have the stuff to do the " acid demand test"? im guessing no becasue it is never mentioned in the kit
    Intex 16x48 ultra frame
    Aug 2010
    Dallas, TX
    4,052
    Re: tf100 test kit
    You don't need it. You use poolcalculator.com, enter the volume of your pool, your current pH, and the calculator will tell you what to do.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: tf100 test kit
    No, it doesn't. You could always order the reagent and use it with the pH tester in the TF100
