Thread: Stabilizer
    Stabilizer
    Hello
    When I went to add Stabilizer it said to add thru the skimmer. But when I did that it clogged up since the granules were bigger than the holes in the original inlet. So reading further down said to mix in a bucket of warm water and broadcast. I did that but the granules never dissolved so worried if I threw it in the pool they set on the bottom and possible eat thru the liner.
    So what to do or over worried about the granules ?
    Thanks
    Mark
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Stabilizer
    It might be best to vacuum them up. They'll end up in the skimmer or filter. In the future, put it in an old sock and hang it in front of a return.
