Results 1 to 8 of 8
Thread: Leak question
  1. Back To Top    #1
    Join Date
    Mar 2009
    Location
    Glendora, California
    Posts
    169
    Leak question
    I feel that I'm replacing more water than usual and will be starting with a bucket test this weekend. My question is regarding a pressure side leak and wondering if I can eliminate it based on this assumption and observation. I notice the loss of water is overnight, I filter during the day, can I assume a pressure side leak would have greater water loss when the pump is running?
    We have been experiencing temperature swings from hot day to cool night and I've read that can also account for higher evaporation.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
  2. Back To Top    #2
    Join Date
    Aug 2010
    Location
    Dallas, TX
    Posts
    4,052
    Re: Leak question
    Either side leak, if in the plumbing, would usually be more prominent when the pump is running. Most leaks are around the skimmer and light though, if that helps you any. That is where both of mine were.
    Built in 1957 44,000 gallon in-ground, Wet Edge Primera Stone in Sky Blue, Intelliflo VF Pump, 600 lb. Pentair Triton II TR-100 Sand Filter, CircuPool RG 60 Plus SWG, TF-100 test kit
    If TFP has helped you, please click to SUPPORT TFP!
  3. Back To Top    #3
    Join Date
    Mar 2009
    Location
    Posts
    169
    Re: Leak question
    The skimmer was repaired when I first bought the house 10 years ago, hmmmm, you can see the patch from the skimmer to the pad. Depending on my results this weekend I'm starting to think it might be worth bringing in a leak detector. I'm preparing for a remodel but need to get this figured out first. Thanks!
    Solaxx Ph-Tek
  4. Back To Top    #4
    Join Date
    Mar 2009
    Location
    Posts
    169
    Re: Leak question
    So I've confirmed the leak and it does leak more overnight when the pump is off. I'm suspecting the skimmer like RobbieH mentioned. I'm guessing that when the pump is on, water running over the leak is slower to leak out as opposed to still water with the pump off. Any way, since I was looking to remodel, I'll have the plaster compnay deal with the leak too, I've confirmed they do leak detection too. Hopefully it's not too expensive and effect the amount of remodel work I will be able to get done.
    *edit* Just got off the phone with the estimator and the plaster folks don't do leak detection. Tonight I'll plug the returns and if it's not them I'm going to shut off the pump for a few days and watch the drop in water level. If it goes much past the skimmer I will call out a leak detector.
    Solaxx Ph-Tek
  5. Back To Top    #5
    Join Date
    Jun 2012
    Location
    Louisville, KY
    Posts
    266
    Re: Leak question
    I've had good results with food coloring. Turn the pump off and let the water get still, then squirt food coloring around suspect areas. It WILL go to the leak and you'll see it immediately.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
  6. Back To Top    #6
    In the Industry
    Qwaxalot's Avatar
    Join Date
    Jun 2012
    Posts
    439
    Re: Leak question
    Skimmers leak all the time. It's caused by the difference in expansion between the deck and the wall of the pool. The leak can be tested with dye. Can be fixed (temporarily) with epoxy at the junction between the skimmer throat and the outside of the pool.
    If the pool is being replastered, a more permanent (but still temporary) fix is to force water stopping cement into the voids around the skimmer, then "white in" the skimmer inlet (to the skimmer throat) with plaster.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
  7. Back To Top    #7
    Join Date
    Mar 2009
    Location
    Posts
    169
    Re: Leak question
    Thanks all, I did put die where the skimmer meets the pool and I could see a slow leak. I plan to epoxy for the short term and to be sure I have no other leaks.
    Qwaxalot, is a skimmer replacement the long term solution? I am considering it as this effort made me take a closer look at my skimmer and I do see cracks on the back of the skimmer wall (area furthest from the pool) but they are above the water line. I think those were self inflicted as my vaccumm plate is slilghtly larger than the skimmer opening on the deck and I give it hard tap with my hand to get it in.
    Can just the skimmer be replaced, or should the plumbing to the pad also be replaced?
    Solaxx Ph-Tek
  8. Back To Top    #8
    In the Industry
    Qwaxalot's Avatar
    Join Date
    Jun 2012
    Posts
    439
    Re: Leak question
    Quote Originally Posted by dravenone
    Yes you can replace the skimmer, but it is NOT trivial, and may well not be a permanent solution.
    The trick is to cut the deck around the skimmer, so that there is enough room to get the old skimmer out (you'll have to cut the plumbing to get it out); then you have to figure a way to solidly attach the new skimmer to the outside of the pool; then, when you patch the deck you have to make sure that there is enough expansion to ensure that the patch and the new skimmer won't be moved as the rest of the deck expands and contracts.
    Whew, sometimes reapplying a little epoxy once a year is not so bad
    Edit: No you usually don't have to replace the plumbing to the pad.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
