Thread: speck E90 - II pump replacement
    Jun 2011
    Nj
    57
    came home to the pool not running
    flipped the timer on just click and nothing
    made sure power was off to the pump
    touched th epump and it was hot
    it is black and in the sun filter was hot too tho
    let it sit an hour
    clicked it on and started up
    but is noisy
    got it primed still very noisy and pressure is dropping from 10 slowly
    so looks like i need a new pump
    i have a speck e90-II right now 1.5hp
    does anyone know the best place to get a replacement one?
    was looking online for prices seems around 500
    called up the local pool place
    they have a hayward super pump 1.5 which is $505
    is one better then the other?
    im leaning towards just getting the hayward as i can pick it up today and be going
    11,000 gal inground fiberglass pool
    Aquarite SWG system
    Jun 2011
    Nj
    57
    Re: speck E90 - II pump replacement
    Replaced with the Hayward
    Very quiet
    Moves alot more water
    Much higher pressure
    Vacuuming is alot easier too
    Went from 12psi on old pump with new sand
    To 17psi with the new pump
    Aquarite SWG system
