Thread: Can seem to get my water clear
    Chlorine at 3, PH 7.3, TC 3. I have cleaned my filter. I have use a filter fiber, maybe less than called for. Added purifier. Any ideas. Pool temp 85.
    40K gal, vinyl, 1 1/2 Starite pump, Sta-rite cartridge filter, tiger shark cleaner
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: Can seem to get my water clear
    Welcome to TFP. What are you using to test? How have you been chlorinating your pool? You're most likely going to need to shock. To help, the folks here will also need CC, CYA & TA values. If you don't have a good test kit I suggest you buy one, it is crucial to maintaining your own pool. There's a Pool School button on the top right, lots of great info in there including test kit options.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Butterfly's Avatar
    South Carolina
    10,045
    Please post a full set of test results, as Mike mentioned.
    Also, did you meet the three criteria to show that you have completed the shock process (a couple weeks ago)?
    See red lines in my sig.
    You're done SLAMing when:
