Results 1 to 12 of 12
Thread: Need tip on reading test kits
    Yesterday I found a post that someone referred to picture tips on a Taylor test kit that was help for someone reading a TF-100 kit. Like an idiot I didn't bookmark it. Anyone know what I'm referring too?
    Hope this in the right spot.
    12,200 gal.
    grey plaster
    IntelliChlor SWCG
    Starite System 3 DE filter
    Round Rock, TX
    529
    Along these lines, for the Tayler PH test. How far behind the kit do you put the white clothe? I find that the color changes if it is directly pressed to the back of the color thingy vs. an inch away.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Feb 2008
    Denton, TX
    5,061
    If you were referring to examples of appropriateness in color change, here's a link I remember. It is specific to calcium hardness:
    http://www.taylortechnologies.com/Chemi ... ntentID=70
    Here's one for CYA:
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    Here's one for differentiating colors:
    http://www.taylortechnologies.com/Chemi ... ntentID=35
    Hope this helps.
    Craig
    Craig,
    Thanks, that was it. I see the link now to more under the chemistry tab.
    12,200 gal.
    grey plaster
    IntelliChlor SWCG
    May 2008
    Arizona
    48
    PH test in TF-100 open to interpretation.
    Quote Originally Posted by lovingHDTV
    I've also noticed this. It seems the PH test in the TF-100 is open to a lot of interpretation due to the color chart. Is there another PH test that can give more accurate results? Perhaps one with a color-changing indicator like the DPD chlorine test?
    Good Times
    If you have trouble reading the colors on the PH test you can get a ColorQ. It is a little expensive and suffers slightly more from high chlorine level interference, but does give a very accurate digital readout of FC, CC, and PH. It also does other tests but they are not as good as the titration tests in the TF-100.
    The standard PH test is really the best choice for most people. With a little practice you can learn to read it very precisely.
    Round Rock, TX
    529
    So how far away from the vial do you place the white background? I find that the color tend to match best if I press the white cloth directly to the back of the vial.
    30,421
    Sorry for any pun, but this is not a "black and white" issue. It's what works best for you. I personally find it easiest to hold the comparator up to a blue sky with no white paper behind it....that doesn't make my method it right, it's just what I'm used to.
    Find a method that your comfortable with and then use the same method each time for repeatable results.
    Guest
    I do the same thing as Duraleigh.
    Round Rock, TX
    529
    Ok, now I just need to get permission to cut a hole in the ceiling so I can see the blue sky from the kitchen.
    Guest
    I use a wonderful invention called a window!
    BTW, trying to color match under incandescent or fluorescent lights is VERY difficult! You really should use daylight.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    I, too, have a hard time matching colours on the comparison tubes. I think colour perception wanes with age somewhat.
    While I cannot tell the difference on the TC bar for values 3 or 5 I can see that it's not 1. 2 is up for grabs most days. Since I do the titration twice a week it's good enough for me knowing that on the in-between days the TC is at least equal to or greater than 2.
    pH is similar. I know that it's not 6.8, 7.2, 7.8, or 8.2. Therefore, it's between 7.3 and 7.7. Again, good enough.
    Last season I stressed over not being able to do a better job reading those colour bars and yet the pool was clear and clean all season. IT doesn't know that my eyes don't work as well as they used to
    AnnaK
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
