Thread: Forgot to make a Bromine bank.....
    at the last fill a week ago. Is this something I can do now after the fact? If so, how much Sodium Bromide should I put in a 500 gal tank? I do have an ozonator.
    I am using the Frog Mineral/Bromine system and shocking with 4.25 ounces of oxidizer once a week on their plan.
    Lazy-L shaped pool and a spa with 6 jets. 22.5k gallons. 2 X 1.5" pool suction. 1.5" loop with 5 return jets in pool return. 2" SPA suction and return. 230 Volts. Pentair 2HP pump and a booster pump. Pentair cartridge filter CCP520 (520 sf). STA-Rite SR400NA heater (400K BTU). Leuder limestone coping. Wooden deck.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Forgot to make a Bromine bank.....
    Yes, you can add sodium bromide at any time to create a bromide bank. There will be some bromide from your bromine tabs, but not that much. Put in the normally recommended amount which is usually around 30 ppm of sodium bromide and which is about 1/2 ounce per 100 gallons.
    Jul 2012
    Herndon, VA
    419
    Quote Originally Posted by chem geek
    if you don't put in sodium bromide, how many tabs would need to dissolve before you had enough from just tabs alone?
    8,000 gallon, in ground, fiberglass pool with a cartridge filter.
    Mar 2007
    San Rafael, CA USA
    12,082
    One usually starts off with around 60 ppm bromine so you'd have to use quite a few tabs to build up to that amount, but that's not a critical amount and you would still be creating bromine with far smaller a bromide bank. In pools, sodium bromide at only a few ppm is used as an algaecide and is activated by chlorine. So I wouldn't worry about it. The main reason an initial bromide bank is created is for a two-step bromine system where no tabs are used (where bromine slowly goes away from outgassing or creation of bromates) or for shocking (say to 10 ppm or more) when tabs are used. By having a large enough bromide bank, you ensure that even shocking produces bromine and does so reasonably quickly (i.e. chlorine doesn't hang around for too long).
