You could, but since there's been some problems keeping FC up you'll want to raise the FC to high target tonight (let's say 8ppm since the CYA is still dissolving) and then test in the AM before the sun is on the pool to see if it's still 8ppm (7ppm is ok too, but no lower). This is the OCLT. If you run the SWG right now you won't know if you lose more than 1ppm overnight.
Set the SWG and pump to turn on after you test in the AM, then run it at least 8 hours tomorrow. Test after it turns off, the FC should be somewhere between 5 and 7ppm. If it is... let the timer turn the pump and SWG back on the next day. If it is lower than 5ppm, you'll need to run the SWG a little more. I'm estimating I can get slightly less than .5ppm FC out of an hour of SWG run time for my pool. You have twice the water I do, so keep that in mind if you aren't seeing ~.5ppm per hour.
