Thread: Newly installed Intellibrite controller problems...
    Aug 2009
    Hi desert,(Victorville) California
    66
    Hello, everyone.
    I have an older pentair intellibrite LED pool light, 120V, w/ integrated 12v transformer.
    Up until tonight, I was using the on/off switch to change colors & patterns, but I've just installed a "new" controller, (#600054) purchased off an auction site & the light now won't change from white, or go to any patterns, the & there seems to be something shorting out inside the controller itself.
    The green light flickers, sometimes the light simply goes off, but will come back on if pushed again, no rhyme or reason.
    It arrived brand new, in a box, did not look used at all, no reason to believe the controller was defective.
    Was I taken by this seller? Or is there something I'm doing wrong w/ the wiring? Or did I just get a bad controller?
    I also re-installed the old switch just to see if the light itself was bad & it was not. It worked fine w/ the toggle switch.
    If there's already an integrated 12v transformer, I shouldn't need another stepdown transformer, should I?
    Thanks for any help...
    Corey
    17,000 gal. IG pool with spillover spa, gunite/white plaster (approx15 y/o, replastered 10/2010), Filter Equipment installed 2007: Pentair CCP520 4-cartridge filter F/R 150, Pentair Mastertemp 250 Gas Heater, 3hp Pentair IntelliFlo Variable 8 Speed Inground Pump(installed 9/2011), and Proud lifetime TFP supporter!!
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    1,963
    Re: Newly installed Intellibrite controller problems...
    I had some problems too however I got it resolved. This thread may help you pentair-intellibrite-light-controller-t22422.html
    Hope this helps
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Aug 2009
    66
    Thanks, Brentr, Hopefully, I'll have the same sucess you did. Will report back.
    Aug 2009
    66
    Brentr...
    That did it!! I just had the wires switched. Works like a charm now. Thanks so much for the link & help.
    THIS is why I'm a lifelime TFP supporter!!!
    Corey
