So I have a cloudy pool, everything is balanced, no phosphate etc. previous owner said had the sand replaced abaout a year ago.I backwash till clear about every 2-3 weeks we havent been in pool in a while and there are zero trees around.Has a slide valve :grrrr: (cant vaccume to waste)
The bleeder valvle works but the gauge reads zero, going to replace tomorrow.
Shop says "you need a new filter" canot afford it right now.
Some posts here say a too big pump can blow sand into pool,around 37,000 gal no spa. Is this pump too big? we have solar and a auto sweep and 2 skimmers, but i think the booster helps some of those.
Should i add "sink n sweep" and then turn main drain off to get more suction from skimmer, then vaccume then back wash. if it clears up and then gets cloudy i'll know its the filter??? a broken latteral?
The main and 2 skimmers are 50-50 but i noticed weak suction, theres 2 return lines one is good flow but the other has nothing(i think its a return)
Any ideas on how to clear it up? thanks everyone!!!
ps.. in video of pool, All thoses bubbles happen when i start filter, go away after a min. is this normal?
[youtube:11jgbu69]usFwFcJPeBg[/youtube:11jgbu69]
[youtube:11jgbu69]e54YcRcA4mg[/youtube:11jgbu69]
