Thread: Gap between concrete deck and pool tiles - repair
    Just bought a house and trying to repair some issues with the pool. There was caulk between the cement decking and the pool tiles which was in terrible shape. So I am in the process of removing all of it and I am planning on using a silicone caulk.
    Is that the right product to use.
    I have seen some pools with the same type of decking and it seems to have more of a grout type filling vs. caulk.
    Any suggestions would be appreciated.
    30,000 Gallon
    DE Purex Triton 2000
    In Ground Pool
    Unsure of Pool Type
    Whisper Flo 1.0 HP Unsure of Flow Rate
    30,424
    Re: Gap between concrete deck and pool tiles - repair
    I would use polyurethane caulk rather than silicone. It is more durable but harder to work with. Worth it in the long run.
    You may need some backer rod in that gap. post back if you don't know what that is.
    Perfect, I will give the polyurethane caulk a try.
    Thanks
    30,000 Gallon
    In Ground Pool
    Unsure of Pool Type
