Thread: How low a pH is safe?
    Jul 2012
    Riverside, CA
    51
    I ask this again since it's a new topic. I am trying to gradually reduce the scaling. I understand I need to maintain a low pH level. My question is:
    How low a pH is safe? The suggested level is 7.5-7.8. Should I stick to the lower end of this range or go lower?
    Thank you!
    20,000 gallons, IG plaster, probably built in the 80's.
    Filter: Hayward Pro-Grid DE6020, 120 GPM.
    Pump: Magnetek century E-plus, Purex Triton Whisperflow, WFE-4C, 1HP.
    Fountain booster: Century Centurion A O Smith, CAT B848, 1HP.
    Spa booster: G.E. Jacuzzi pump
    Heater: Raypak RP2100 Digital, Low Nox
    38,520
    Re: How low a pH is safe?
    Keep it at or above about 7.2 ... lower can start to cause problems with equipment and be irritating to the eyes.
    Jul 2012
    Riverside, CA
    51
    Got it. Than you, Jason.
    Jul 2012
    Dumfries & Galloway, Scotland
    296
    Ditto Jason 7.2-7.4 would be comfortable and assist in your scale problem, 7.5-7.8 is not really going to help you very much, if at all, FYI 7.2-7.8 is the acceptable range for a plaster pool with the human eye being at 7.5, making the ideal comfort range for bathers 7.4-7.6
    Stuart Murray
    Scotland UK
    UK NPPOC
