Results 1 to 15 of 15
Thread: Raleigh North Carolina area?
    I am wondering if anyone in this area leaves their pump running over the winter instead of closing down and winterizing? It seems to me that it would be feasible to do this but wanted to hear what others in this area are doing. Last year I shut down and drained the equipment but found that the problems were many keeping the water off the cover, trash off the cover, etc. My winter cover is not a very high quality one and is certainly not good enough that the rain water doesnt get through the cover and therefore let trash into the pool water. Any fellow area pool owners care to comment on their experiences and have suggestions?
    27 foot round above ground
    30,129
    Re: Raleigh North Carolina area?
    My pool stays open year round as do many others in North Carolina. It's a trade-off in workload but you should try leaving it open one season and see if it suits you.
    I am seriously considering it. The only consideration I had was that I know we can get some excess cold weather on occasion and was wondering if we got some zero degree cold for a day or two would the flow of water through the pipes keep the system from freezing. Have you ever encountered such a cold smap here? Did it present problems?
    I guess keeping the pool open in the winter is just like in the summer? Or are there other considerations you may point me to for the winter operations?
    Jul 2012
    South Carolina
    48
    I am in south carolina, and we keep ours open year round and have for the past 8 years with no problems. Still follow same procedures for balancing but lots less work since lower temps.
    15 K gallons
    Gunnite
    Centurion Pump/Hayward Sand Filter
    Polaris 360 Robot
    Jul 2012
    Newton NC
    31
    I am located in Newton NC. I close my pool only because of massive amounts of leaves. It does not get cold enough here to cause any freezing problems. It may not be warm enough to swim in the winter but our temps are still too warm to keep our pool closed all winter.
    16k 17X33 IG Vinyl(2000), Pentair Intellifo Variable Speed Pump(2006), Hayward Sand Filter, Aqua Rite SWG w/T9 cell(repl 7/2011), Hayward Natl Gas Heater, TF100 w/magnetic stirrer
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    I'm watching this thread with a lot of interest since I am in Charlotte NC area and have a similar climate.
    This site may be useful:
    http://www.climate-zone.com/climate/uni ... -carolina/
    The advice I have gotten has ranged from "Do a full closing" (another TFP member in Charlotte) to "drain the pump and filter and cover the pool but don't blow out lines etc." to "cover and run the pump when below freezing". Frankly I'm totally confused at this point but reading threads like this one trying to understand what questions to ask to help make up my mind about what to do.
    SaltyPool - I have a massive amount of leaves also but by winter time the leaves are all gone and that does not seem to be an issue here for me. When the leaves are an issue is all the other times. Right now when we have a thunderstorm the skimmer will fill up every night to the point of being almost completely clogged. We have a net that attaches to the edge of the pool that catches a lot of them but not all by far. This is an issue when we have to go out of town for a week or more.
    wish I could find some technology to deal with this leaf problem. Anyone recommend anyone reliable that can be employed to care for the pool on occasions when you are out of town?
    Jul 2012
    South Carolina
    48
    Quote Originally Posted by UnderWaterVanya
    We don't have leaf issues. Just keep pool open, And test as usual. We end up being able to cut our pump run time in half as well as chlorine use. My kids swim in cold water as early as march and go through October. They are crazy.... So we just keep it up.
    The advice I have gotten has ranged from "Do a full closing" (another TFP member in Charlotte) to "drain the pump and filter and cover the pool but don't blow out lines etc." to "cover and run the pump when below freezing". Frankly I'm totally confused at this point but reading threads like this one trying to understand what questions to ask to help make up my mind about what to do.[/quote]
    15 K gallons
    Gunnite
    Polaris 360 Robot
    For those of us that have leaf problems I found this old thread on the site that may just offer us some relief... low-cost-leaf-blocker-t28778.html
    Bluegrassman's Avatar
    Jan 2012
    West KY
    243
    My main concern with not closing a pool in a region that may have freezing temps would be what happens in an extended power outage? No power = no circulating the water which could lead to equipment and plumbing damage
    18x36 Vinyl IG ~27,000 gal, Intelliflo VF Pump, 300# Sand Filter, Polaris 280 w/Pentair Booster Pump, Pentair EasyTouch w/ IC40 SWCG
    TF100 Test Kit
    SpeedStir
    Oct 2011
    Mebane, NC
    19
    We're located in Mebane, NC and had our pool installed last October. I kept it open and uncovered all winter. There were a few weeks of lots of leaves but once that was over there wasn't much to do. I put a couple of chlorine tabs (which I don't use during the swimming months) in the two baskets and balanced the water. I vacuumed when I thought it was needed. I ran the pump at night when the temperature was going below 36 and would have also run it all day when below this temp - which never happened last winter!
    The reason I kept it open is that I'm 67 years old and my daughter & I thought we'd have a hard time putting a cover on and taking it off, blowing out the lines, etc. Plus we'd still have to contend with leaves on the cover as well as water. It was nice to look out the window and see the uncovered pool during the winter months. I'm going to do it again this year.
    My pool store put me on EZ-Pool for the winter and I knew I had to find another way to take care of my water and still be able to afford to run the pool. EZ-Pool is VERY expensive. I found TFP and have been on BBB all summer. When I had a bit of a cloudy condition, the TFP folks walked my through shocking the pool. What a terrific forum!
    Hope this helps!
    20 x 40 IG 26,000 gal. vinyl
    Hayward sand filter S244T 62 GPM
    Hayward 2.0 hp Super Pump Mdl SP2615X20
    T-100 Kit
    Pool School
    Cedar Island NC (Outer Banks)
    84
    Following this also. Live on the Outer Banks and we almost never get a hard freeze. Impossible to cover because of wind.
    My question is if algae is a problem when the water is at, say, 40-50 degrees? We usually snowbird in our RV so it would be left unattended for several months.
    I have a SWG but I recall that it doesn't work below 60 degrees or so? If that is true I could put in a dummy cell and just use chlorine.
    Cedar Island NC (Southern Outer Banks)
    Splash Super Pool (40x20)
    29,000 gal; AG; Sand Filter; 1.5HP pump. Use the cosmic Taylor Test Kit
    New Aquarite SWG w/T-15 cell; New Dolphin Supreme M4 Robot cleaner
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by belgique
    What type of chlorine could you use that would last while you were snowbird'ing?
    84
    I could have a friend dump some in and I see that some folks hang a container with pucks in the pool. From other reading, it would seem to not be a big deal if the water stays in the 50-60 deg area?
