Results 1 to 12 of 12
Thread: Pump turns off
    Pump turns off
    The timer switch is still in the on position and the breaker is set, but the pump turns off. Its not a PG&E issue because the waterfall pump still works. I am not hearing any extra noises from the pump as if it is straining...
    My first time here, and I want you to know I appreciate all your work!!!
    Phil
    22,551
    Re: Pump turns off
    Welcome to TFP.
    Is the motor hot when it stops?
    What happens if you manually turn the timer off then back on?
    Re: Pump turns off
    Yes, the motor is very hot and flipping the switch does nothing.
    May 2009
    Youngsville NC
    395
    Re: Pump turns off
    Pool pumps are intolerant of voltage deviations from spec (they get hot and trip the thernal protection), you also need to check (with the power off) that the shaft / impeller turn freely. If this isn't also right, , again the motor will heat up and thermal trip.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    22,551
    Re: Pump turns off
    How old is the pump?
    Has anything changed lately? (eyeballs removed, filter changed, plumbing reworked,etc.)
    Re: Pump turns off
    No nothing has really changed.. the pump is about four years old. I tried switching the condenser between the waterfall pump and the main, but that it did seem to change anything...
    May 2009
    Youngsville NC
    395
    Re: Pump turns off
    Quote Originally Posted by pkozicki
    Did it or did it NOT seem to change anything ? Your sentence is unclear....
    Re: Pump turns off
    It did not change anything, it still turns off. When I got home tonight it was hot and smelling of burned motor but going... I pulled it out and the impeller turns fine.
    22,551
    Re: Pump turns off
    It's probably time for a new motor. What model pump is it?
    Jun 2011
    Nj
    57
    Re: Pump turns off
    just happened to me
    came home pump was not on but hot as ****
    turned power off to it
    let it cool down some
    turned it on started up made alot of noise
    turned off took the motor off of housing
    spins up fine but noisy
    time for a new pump
    picked up a new pump
    AMAZING difference
    much higher pressure
    much higher volume of water movement
    vacuuming is a lot quicker now due to increased suction pressure
    the age of the old pump was unknown as it came with the house when i bought it
    11,000 gal inground fiberglass pool
    Aquarite SWG system
    Re: Pump turns off
    No sticker except for the one that give volts, hp etc. It says its a Smith 2.2 hp. Is rebuilding it a good option?
    22,551
    Re: Pump turns off
    Replacing the motor is probably worth it but they won't rebuild that motor. I'd still suggest a 2-speed motor.
