Results 1 to 11 of 11
Thread: Bad winding, 2 yr old 3HP AO Smith, causes?
    Mar 2008
    Lafayette, LA
    108
    My main pump motor began making noise a couple months ago. After I got back from my last hitch offshore, it was tripping the breaker after trying to start for 5 or so seconds. I could still spin the shaft by hand, but could feel a rumble like a bearing had gone. There was no moisture to suggest the seal had gone bad.
    Took it a repair shop yesterday, and they diagnosed a bad bearing housing and bad winding. AO Smiths warranty is one year, so I'm out of luck on that. I would like to avoid replacing this motor again in a couple years, so can you tell me what may have caused the failure?
    7x7 spa drains>16K IG, Gunite/Plaster, Compool 3600, Purex Triton Minimax Plus 350, Sand Filter, 8 Gal Liquidator
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Bad winding, 2 yr old 3HP AO Smith, causes?
    Bad bearing caused overheating of the insulation of the windings if there is no leak is one guess. I realize that a 3hp motor is pretty large, did it replace something that was larger? Could the pump (wet end) be partially clogged adding an additional strain on the motor?
    Just a couple ideas.
    Mar 2008
    Lafayette, LA
    108
    It does have to pull through a full skimmer sometimes. I'm out of town for a month at a time occasionally and the wife has her hands full with the kids. Your guess makes sense.
    Is there a more rugged motor available? This is an AO Smith B2848 motor for a Whisperflo pump.
    Apr 2011
    Murrieta, CA
    2,360
    I'm pretty sure AO Smith is the standard, do you have a bottom drain, maybe you could draw more water from the bottom drain instead all from the skimmer.
    Qwaxalot's Avatar
    Jun 2012
    439
    That's an awful lot of pump for a pool that size. Unless you have lots of large intake and return plumbing, Consider putting on a smaller impeller.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Mar 2008
    Lafayette, LA
    108
    No, I have AquaGenie skimmers with no bottom drain. That would have been a good idea though, thanks.
    The motor for my Polaris went out for three months, I'm sure that contributed to the load in the skimmer baskets. Now that I have it running again, hopefully it will make it easier for my to keep things cleaned out while I'm gone.
    I found a replacement motor for about $375 shipped. Looks like I'll be ordering it, plus a new PS 1000 seal kit tomorrow.
    38,251
    If you have not ordered the motor yet, why are you not considering a smaller motor and impeller? Likely would cost less than the 3HP motor and would save electrical costs.
    For that matter, you could likely get a 2-speed motor and impeller for around the same cost as the 3HP.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    What was the cost of having the motor shop rewind? Maybe even add a second speed?
    -- Guy --
    Mar 2008
    Lafayette, LA
    108
    Quote Originally Posted by techguy
    He didnt even consider it. Said he would only rewind 30HP 3 phase or bigger motors.
    Mar 2008
    Lafayette, LA
    108
    Quote Originally Posted by Qwaxalot
    OK, you guys have my attention. I figured they used 3HP in order to have enough flow/pressure for the spillover spa.
    Can a compool 3600 control a 2 speed pump?
    What info can I get you guys to help me decide if I can downsize and/or go with a 2 speed motor?
    Thanks for all your help.
    Mar 2008
    Lafayette, LA
    108
    Did not place the order today. Still considering my options, any input would be appreciated.
