Thread: sand filter valve question...
    Jul 2012
    CA
    240
    Hi there everyone, i have a white cloudy pool with a little dust in shallow end. On a sta-rite 2 piece sand filter Slide push/pull valve how would i rinse or vacuum to waste, flock first right? (Or is flock only for green water?) PG replaced pump with a bigger one i when they installed solar, could that be part of the cloudy issue? Too powerful pump pushing through sand? Hey thanks for any ideas.
    25k I/G ecostar ccplus Polaris plaster
    22,403
    Re: sand filter valve question...
    With a slide valve there's usually no waste function. You could disconnect the pump discharge and plumb it to the waste line.
    Jul 2012
    CA
    240
    ok, so would it be as easy as cutting after pump, put a diverter valve(red kind at lowes? then just have pvc run along side of filter backwash pipe?
    I have never glued pvc b4, im sure you tube has some vids on it. Hey thanks bama!
    22,403
    I didn't find a diverter valve on the Lowes but if it's a 3-way valve it'll work ok. I'd use a Jandy type valve instead because they have lower head loss than the standard PVC valves you can buy.
