Thread: Question, going away for five days
    I am still transitioning to BBB, but cya is still a little high (75). FC at 24 going to bring it up to 30 to hyperchlorinate before going on vacation. Question is, planning on putting some trichlor in the chlorinator, how many pucks and what to set dial on? Hayward chlorinator has dial that goes from 1 to 10. sand filter runs for 6 hrs a day, solar cover, full sun from 7am till about 5. IGP 26000 gals
    26000 igp hayward sand filter 1.5 hp pump 4 returns 2 skimmers 2 main drains interfab extreme2 water slide taylor k2006 test kit
    Jul 2009
    Olney, MD
    218
    Re: Question, going away for five days
    By using the pucks in your chlorinator, you are only going to increase your CYA and make that situation worse. If you are only going to be away for 5 days, I think bringing it up to shock level (21) and leaving the solar cover on you should be fine... unless you are currently dealing with some algae...
    You should update your signature line to include info about your pool, then you will get the most accurate advice. You might also post your last set of full test results, good to have everything in check before going away, then things are less likely to get out of hand.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    Thanks, was thinking that I didn't need pucks anyway, just didn't want to come home to a green monster. Going to bring fc up to 30 and no pucks and hope for the best. No algea issues at this time, but had them 3 days ago and that is why I began shocking. BTW signature line updated a bit, when I figure out exactly what I have i'll be more detailed!
