Thread: New TF Test Kit Numbers
    Brought CYA up from 60 to 75:
    FC = 5.5
    CC = .5 Just A Hint of Pink (Almost Clear Before adding Drop)
    CYA = 70 / 75
    PH =7.8
    TA = 110
    CH = 250
    Salt = 3600 (Taylor K-1766)
    What is next? Lower PH to 7.2 To lower TA to 70: Then areate to bring PH back up to 7.6 / 7.8??
    IG: 11' x 26' Fiberglass (6,700 Gallons), Hayward 1 HP 2 Speed Pump, Hayward Sand Filter, P4 Aqua Logic Controller, T-15 Salt Cell. TF-100 Test Kit
    38,475
    Re: New TF Test Kit Numbers
    Looks pretty good, I would just lower the pH to 7.2/7.4 and enjoy.
    There is really no requirement to actively try to lower the TA, it will lower each time you add acid. The aerating will just require you to add the acid more quickly. Just be patient and see if the pool finds a nice pH equilibrium eventually.
