Thread: I came back to emerald green water
    After 2 weeks away, I came back to emerald green water. I followed directions and now all the green is gone, but the water is still very cloudy after 10 days. I can barely see the pattern on the bottom of this 4' deep pop-up pool. I am running the sand filter 24/7. I have periodically added DE, per instructions, but the return flow decreases so drastically (even though the pressure only rises slightly) I generally backwash after an hour. I really want my sparkling beautiful water back. Am I just being impatient? Should I give up, drain and refill? And, for future reference, is it possible to load the pool with chlorine prior to leaving and come back to a better situation?
    Thanks for all the great info on your site!
    Third time's a charm!
    5455 gal., 18' X 48" Intex pop-up
    Intex Krystal Clear Sand Filter Pump, 1050 gal/hour
    Apr 2011
    Lynchburg VA
    393
    Re: I came back to emerald green water
    Yes, you can load up chlorine in your pool prior to going away by bringing your pool up to shock level just as you leave. You can also use pucks while you are away and deal with the slight rise in CYA when you get back. The cloudy water is the algae you have killed and the only way to get rid of it is to filter it out or re-fill.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    You can definately shock the pool before leaving next time. Covering it with a solar cover, just below shock level also helps reduce FC loss.
    I normally do not advise this, but on a 6k gal pool but it maybe faster and more economical to do a substantial drain and fill if you are on city water and not in drought conditions. Intex filters tend to be terribly undersized and you'll want to maximize what swim time you have left.
