Thread: Sulphuric acid versus muriatic acid
    Alberta, Canada
    177
    So the place I get my chlorine does not have muriatic acid but they do carry sulphuric. They tell me it will do the same thing in lowering PH without the nasty side effect of out gassing in the mechanical room.
    Any thoughts on this? Is it diluted the same 4 to 1.?
    Will it still read the same on my probe for the auto feeder?
    Thanks for your help.
    Deena
    http://www.lindbrookstargazer.ca
    100,000 liter IG vinyl liner
    Rolachem Chlorine & Muratic acid Auto feeders/Pool Perfect Auto feeder
    Pentair 30" filter (Tagelus) Sand filter/Centruion switchless pump 1.5/.25 HP
    37,399
    Re: Sulphuric acid versus muriatic acid
    See this for a brief discussion (maybe try the search feature):
    sulfuric-acid-to-lower-ph-t16950.html?hilit=sulfuric%20acid
    I assume the probe is reading the pH ... so that would not be affected, but not sure it is good to mix the 2 in the auto-feeder.
    Alberta, Canada
    177
    Thanks Jason. The only postive I see right now is the no out gassing.
    I would not mix the two, just use one in place of the other.
    I think I will stick to muriatic acid.
    Deena
