Thread: Water feels sticky? & pH still high
    Pool water is crystal clear (a little too clear as you can see some stains at the bottom of the deep end!)
    I ran a test this morning, our water feels "sticky", for lack of a better word.
    FC 6
    TA 95
    CH 250
    pH 8.2
    CYA 50
    I know I need to adjust for pH, so far I have added 1.5 gallons of MA to little avail - thoughts? I am adding it through the skimmer - right idea?
    Thanks as always!
    40,000 gallon in-ground pool w/ a spa inset. white Gunite, in-floor Caretaker system, Triton 2 tr-100 sand filter w/ zeobrite
    May 2012
    Boyd, Texas
    93
    Re: Water feels sticky? & pH still high
    The acid should be added in front of the return not into the skimmer. That being said it should still be dropping your PH. How long did you wait after adding to test it again?
    6500 gal, Intex 18'x48" above ground, 1hp Pro Sand Filter, TF100 Test Kit
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by kco82
    Don't put it in the skimmer. The high acid concentration can do damage to the equipment. Instead pour it slowly in front of the return jet, letting the water mix it in.
    Since the pH test tops out at 8.2, your pH was likely much, much higher. Add more acid, let it mix for 30 min, test. Repeat. pH is important, so get it in line before you tackle the other issues.
    Aug 2010
    Dallas, TX
    4,052
    As a rule, don't add anything to your skimmer. Even CYA I prefer to hang in socks in front of a return rather than put in the skimmer.
