Results 1 to 14 of 14
Thread: Treating algae - can't identify what kind it is - need help!
    Jun 2012
    Minnesota
    12
    Per local pool store (I know, I know), they are claiming (without seeing it) that I do in fact have mustard algae. It has turned from a medium brownish fine dust to a lighter brown. I vaccum it up, it's gone only to return the next day. Its been a very warm summer for our neck of the woods and my FC levels have been lower than they should be this summer as well, below 1.0, FC is now reading 3.8 (SWG), and all other numbers are in line with what is acceptable ranges. Borates also finally increased from 15 to 80 after adding 35#'s of boric acid. I'm also looking at replacing our Jandy cartridge filters at 3 years old which were quite dirty after my last cleaning. I'm just not convinced its mustard algae but do believe it is algae of some sort. I'm really unsure how to treat the situation. Pool store has said I need to vaccum to waste, replace water as necessary, treat with mustard algae black magic,8#'s of zip chlor and 4 oz of severest algae treatment throwing in all pool toys, brushes, etc. What can I use other than the expensive zip chlor?
    I would also like feedback and a good test kit. I can spend hours looking at them, but I really don't know what I'm looking for and just want something user friendly, accurate/reliable so I can break free of the pool store games.
    2010 18' x 40' IG, SWG
    27,000 gal, vinyl liner
    Jandy Aquapure salt chlorinator
    Mineral Springs Salt Sanitizer
    Jandy CL460 cartridge filter system
    Polaris pool cleaner
    Coverstar auto safety cover
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: Treating algae - can't identify what kind it is - need h
    Bleach kills all :>)
    We need some test results. Have you performed an overnight chlorine loss test? Have you tried rubbing/brushing the affected area?
    22,551
    As for the test kit just order the TF-100 from tftestkits. There's no finer kit out there.
    I suspect that it's not mustard algae. Does it grow only on the shady side of the pool on the walls? If it doesn't, it's most likely either green algae or just dust and dirt.
    Jun 2012
    Minnesota
    12
    I'll have to pull my numbers and post - I don't have them here at work. This only appears along the creases, depressions of the liner and along the steps, in corners and around the drain. It's very fine and I can't use my polaris to vaccum it as "ALEX" just moves it around. No scrubbing at all necessary, poof and it's gone. I am siding more with dirt/dust as we are still excavating around the pool. We do keep our autocover on whenever the pool is not in use because of this. I'm wondering if the cartridges became so dirty (altough my Jandy meter wasn't reading anywhere near this) and now just need replacement. (At night, it appears fine particles are blowing in from the jets.) Another beef I have with pool store - don't clean them until the meter tells you it's 'dirty'...Wrong! Will be cleaning at least twice a season with my new set no matter what it reads. Thanks for the advice on the kit, I will review this one.
    2010 18x40 IG, SWG
    Aug 2010
    Dallas, TX
    4,052
    There is nothing wrong with waiting until your filter's pressure tells you it's time to backwash. That's what I do. I went the whole swim season last year without backwashing, then when fall hit I had to a few times due to what leaves were putting into the pool.
    Jun 2012
    Minnesota
    12
    We don't backwash, but remove the 4 cartridge filters entirely and spray them off. They were literally caked with dirt, hair and bugs. We pulled out the pressure washer to gently get them decent looking while I order new ones. At clean, the meter reads 10, dirty is around 24. This was reading 18, but they looked terrible.
    Aug 2010
    Dallas, TX
    4,052
    I couldn't tell what kind of filter you had.
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Quote Originally Posted by SwimMNgirl
    Read the section on filters in pool school. The basic advice is that you clean each time you have a 25% rise in pressure. That would mean that around 12.5-13 lbs you should be cleaning.
    Jun 2012
    Minnesota
    12
    Posting latest test results:
    TC/FC = 3.8
    pH = 7.6
    TA = 130
    Calcium Hardness = 300
    Stabilizer = 40
    Copper = 0.0
    Salt = 3000
    Borate = 80
    30,424
    Reading your first and last post, I think you may have algae but what you are seeing is actually dead algae that accumulates as it dies.
    Do you have your good test kit yet so you can shock the pool correctly?
    Jun 2012
    Minnesota
    12
    I don't have a good test kit (yet) - I'm working on that - reviewing the TF-100. Is that one people seem to be happy with?
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    The test kit Dave sells is great. It uses the same test reagents and tubes as the Taylor kits but in larger but less expensive versions. I thought it would be more complicated than the color blocks and the ilk but it's actually easier.
    My example is when looking at the yellow OTO CL test this week. I did the color block test and using several different background colors (white card, sky, pool...) I could not tell if I had 3 or 5 PPM. I knew I wanted to get it right as it was going to be hot.
    So, I got out my test kit. I added the water, added one big scoop of powder, swirled it until I got a nice rich pink color. I then added drops one at a time until all the pink color was gone... 5 drops, 2.5 ppm CL. I knew exactly how much CL I needed... all done. The nice thing about the test kit is most of the color changes are easy to see. Pink->clear, Green->Red
    Late edit: This is the TF-100 test kit. You will be very happy.
    -- Guy --
    38,305
    Yes
    See the link in my signature for a comparison of the K-2006 and the TF-100 ... you get much more of the reagent you need with the TF-100. You will quickly run out of some of the reagents with the K-2006 (if a test requires 5 drops from one bottle and up to 40+ drops from the other bottle ... why would they come with the same quantity???)
    Jun 2012
    Minnesota
    12
    Thank you for the comments - I appreciate it!
