Results 1 to 8 of 8
Thread: liner is slippery
    liner is slippery
    we have a 18 ft above ground pool liner is slippery
    scrubbed weekly
    tested weekyl by are local pool store (by the way will not try and sell you anythig if the water tests ok)
    and so far no stuff bought
    how do i get rid of this
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Re: liner is slippery
    What are you using to chlorinate? First guess would be a very fine coat of algae. Go to the pool school link above and read about shocking the pool.
    -- Guy --
    monkeywrench's Avatar
    May 2008
    Shrewsbury MA
    84
    Sounds like the start of something bad ,you should shock, here we use the BBB method, so some bleach would be in order and more brushing. Please tell us if you do any testing of your own, filter type, what your using for chlorine now, size of the pool in gallons. The rest of the folks are going to chime in and want to know all your pools store numbers and then tell you to start doing your reading in pool school and also to get your own kit. I prefer the TF100 linked to here, I have a half dozen friends using it now and they love it.
    jb
    14x28 IG Vinyl
    12.5k gal
    Hayward SP-Super Pump
    Hayward Pro-Grid 36sqft DE
    Hayward auto chlorine feeder (offline:using BBB)
    Hayward AG Gas heater
    30,426
    Yeah, a slippery liner is almost always indicative of an algae flare-up and the correct cure is to shock the pool. Like has already been posted, read "The ABC's of Pool Water Chemistry" up in Pool School then, read "How to Shock Your Pool".
    use clorine in ont bleach is more expensive
    have kept it at shock level for a week
    it scrubbed it daily and still slippery
    can't post numbers as i do not have a test kit just use strips
    pool store is saying water is great except the high clorine
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,409
    Without current test results we can't tell you if have raised the FC high enough to complete the shock process. Ask the pool store for a print out of the test results or write them down. We need results for FC, CC, TA, pH, CYA, and CH.
    Love TFP? Become a
    TFP Supporter!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    One more question, is the liner new? Like others have said usually it is a sign of bio-film from algae trying to grow, but I have also seen liners be slippery sometimes if they are new.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Get a proper test kit, read pool school, buy bleach.
