Results 1 to 7 of 7
Thread: Hayward Heater problem
    Can anyone help I have a Hayward Heat pump for my pool but now when I turn it on code HIA shows up first thing, the heat pump works, it seems to take a little longer than usual to come on. What do I need to do, please help if you can do not want to cause more problems by using it. Thanks
    Apr 2011
    Lynchburg VA
    393
    Re: Hayward Heater problem
    HI is the only thing I could find in the manuals and that is either a low water flow indicator or a high water temp indicator.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Can you verify the code? I can't find anything under HIA.
    HIA 2.1 is the code it shows then it starts up after a few minutes.
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    Call Hayward Customer Support, 908.351.5400. What you are seeing could just be the version of the code for the system board.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Thanks
    I had the same code displayed when my heat pump quit. At first I thought it was the fan so I replaced it but still had the same trouble - compressor would start but fan would not spin up. I could bump the fan blades and it would run for a bit then shut down again. I finally replaced the Fan Run Capacitor (part no. HPX11024151) and that did the trick.
