Thread: How close do pump and SWG rates have to match?
    Finally made the plunge in to the Intex metal frame world recently. I'm intending to add a sand filter and SWG to the 16' x 48" before next season.
    For the SWG, I think I've settled on Intex #54601, rated at 1650gph. For the filter, #56673 matches this flow pretty well at 1600 gph. For not much more money, I could get #56671 with nearly 2X the media. Is a 2650 gph pump too much for the 1650 gph SWG?
    Thanks.
    22,545
    Re: How close do pump and SWG rates have to match?
    The 2650 pump should work fine with the 1650 swg.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    I'm with Bama, you shouldn't have any issues.
    Very good. Thanks for the quick responses.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I know you have gotten an answer to your question, but I thought I would mention low flowrates are usually the issue with swg's...not high flow rates. For example, I was running the swg you mention with the intex 637R catridge/pump which is rated at 1000 gph. It worked fine with this pump when the cartridge was clean, but usually didn't work when the cartridge was slightly dirty due to the lower flow.
    The intex swg will have no problem with either of the sand filter your mentioned.
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    I agree with the posts above. I can assure you they are quite compatible. I read somewhere on this forum today that the 2650 is currently priced only $30 more than the 1600. The 1600 is a fine system. But for $30 more the 2650 is a far better deal.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
