Results 1 to 11 of 11
Thread: Shock process
    Jul 2012
    Riverside, CA
    51
    Shock process
    Should I leave the pump on for the entire shock process? Thank you!
    20,000 gallons, IG plaster, probably built in the 80's.
    Filter: Hayward Pro-Grid DE6020, 120 GPM.
    Pump: Magnetek century E-plus, Purex Triton Whisperflow, WFE-4C, 1HP.
    Fountain booster: Century Centurion A O Smith, CAT B848, 1HP.
    Spa booster: G.E. Jacuzzi pump
    Heater: Raypak RP2100 Digital, Low Nox
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Shock process
    xiaobulu:
    Yes, I would leave pump on for the entire shock process. Just keep an eye on filter pressure and clean/backwash as needed.
    Jul 2012
    Riverside, CA
    51
    Re: Shock process
    Quote Originally Posted by BoDarville
    xiaobulu:
    BoDarville: thank you for your response! My pool passed the 3 tests within 24 hours. Just to be safe, I am shocking it to algae killing level for another 24 hours. The pump is working fine. Pressure did not go up much. Do I need to clean it any way?
    Jun 2010
    Glendale, CA
    513
    Re: Shock process
    No need to clean the filter unless you need to. Sounds like you had a very mild case of algae - so the impact on the filter isn't going to be anything like what you see in the more extreme cases.
    16K Gal Plaster | Compupool SWG | Intelliflow VF | TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Shock process
    Since it's mostly fresh water now and the old water wasn't green, I didn't think it would take long to kill the algae on the walls and around the skimmers. Nor would the filter clog with dead algae.
    So...post us some numbers and some pictures of how clear the water is!
    Keep the pH low and work the scaley areas over with the wire brush. It will take a long time to remove it, but it should quickly get smoother to the touch.
    Jul 2012
    Riverside, CA
    51
    Re: Shock process
    Nice, I didn't want to have to clean the filter I yet to learn how to do that.
    Quote Originally Posted by Richard320
    I didn't think so either. CC is never greater than 0.2 and the water is always clear, actually sparkly after the shock. The little green around the skimmers you spotted were gone in no time. The yellow on the walls and bottom grew a bit during the long refilling process. In retrospect, I should've added chlorine during the refilling. Anyhow, the yellow is much reduced since the "drain and refill" was completed. I have been pouring jugs after jugs of liquid chlorine and brushing diligently.
    Sure. I can't wait to show off. But at this moment, the FC level is probably too high for me to test the pH accurately. I will test when the FC level is back to normal. By the way, my daughter and I love the test kit. It's so much fun! We tested so many times in the past 2 days that we almost used up all the chlorine reagent that came with the Taylor 2006. Should I stock up with this 16oz bottle? It's cheaper but is it too much?
    Yeah, this is my next task. Although my pool has never looked better before, I become pickier now. The remaining yellowish scaling bothers me greatly. How low a pH is safe? The suggested level is 7.5-7.8. Should I stick to the lower end of this range or go lower?
    I've learned a lot these days. You guys are the best!
    Jun 2012
    Howell, NJ
    977
    Re: Shock process
    Quote Originally Posted by "xiaobulu"
    Sure. I can't wait to show off. But at this moment, the FC level is probably too high for me to test the pH accurately. I will test when the FC level is back to normal. By the way, my daughter and I love the test kit. It's so much fun! We tested so many times in the past 2 days that we almost used up all the chlorine reagent that came with the Taylor 2006. Should I stock up with [url=http://www.amazon.com/Taylor-FAS-DPD-Titrating-Chlorine-R-0871-E/dp/B004BGT62M/ref=lh_ni_t
    this[/url] 16oz bottle? It's cheaper but is it too much?
    I have read where it says to replace your reagents each year, but I decided to buy the 16 oz bottle anyway. It is so much cheaper per ounce, I couldn't justify buying only .75 oz. I guess I will find out next year if it is still good. I'll just give you a tip: It is cheaper to buy direct through Amato than it is through Amazon.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    38,301
    Re: Shock process
    Also some of the reagents are cheaper from tftestkits.net ... although Dave does not sell the huge 16oz bottles (that is a LOT of testing and hope it does not go bad on you).
    Jun 2012
    Howell, NJ
    977
    Re: Shock process
    I have it stored in a cool, dark cabinet, so it should last a while. Is there any way to test these reagents, to know if they are bad? I guess if I find out that it is bad, I will just order the .75 oz bottles from now on.
    John
    38,301
    Re: Shock process
    This tells you how to tell when they go bad:
    extended-test-kit-directions-t25081.html
    If you keep it in the closet it should be good for at least a year, but that quantity is probably enough for at least 5 years (if you do not have to shock the pool) and that may be pushing it. There are also 2oz bottles that work well.
    Jul 2012
    Riverside, CA
    51
    Re: Shock process
    5 years? That's too much. I will probably order the 2oz bottle. Thanks for all your inputs.
