Results 1 to 14 of 14
Thread: Sanitizer for indoor pool in the Olympics?
    Hurricane Gio's Avatar
    Apr 2010
    Coral Gables, FL
    197
    I was wonder what they use? Can't use Bleach indoors correct? Salt? Ozone? Baquill?
    Always wondered since into my pool 3 yrs ago.
    8,000 Gal, 11 x 26.8ft Shotcrete Pool with "Cool Blue" Diamond Brite by ESSIG Pools with Artistic Pavers Deck
    Goldine AQL-PLUS w/Aqua Pod, Aqua-Rite T-CELL-15 SWG, Pentair WhisperFlo High Performance 1.5HP, 2 speed pump, Pentair IntelliBrite,
    Pentair 100sqft Cartridge Filter, 6 Pool returns, Skimmer and 2 Anti-Vortex Main Drains
    Pool's completed build 2/2010
    Jul 2009
    Olney, MD
    218
    Re: Sanitizer for indoor pool in the Olympics?
    Why do you think you can't use chlorine indoors?
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    They are using a combination of chlorine, UV, continuous floc in the sand filters, and extreme circulation. One of the more entertaining features is the use of variable speed pumps that automatically change speed as the bather load varies, so that filtration always remains at optimal levels relative to the bather load. Another green feature is the use of the backwash water to flush the facility toilets. They claim that they are getting one micron filtration by using floc combined with 1 meter deep sand beds with specially graded sand.
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    I know the pool in Atlanta for the 96 games was on liquid chlorine. Had a aquasol controller on it & they kept the chlorine at 10 ppm
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    Apr 2010
    Coral Gables, FL
    197
    I always heard that you could not use chlorine indoors due to vapors during evaporation. I guess another myth?
    coffeegoddss's Avatar
    May 2012
    Minooka, IL
    93
    Haha! My husband looked at me last night and asked how much bleach I'd be using in a pool that size.
    AG, 10,400 gallons, filter cartridge, 2HP pump
    Coffeegoddss...bonafide thread killer!
    POOL SCHOOL...fortheloveofgawd, read POOL SCHOOL
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,112
    I just figured they tossed a few pucks in a floater and called it good.
    Quote Originally Posted by Hurricane Gio
    Almost all indoor pools use chlorine. Air quality issues are a common problem with indoor pools. Chlorine it's self is not the problem. However, several chlorine disinfection byproducts (CC) tend to get into the air and can create serious issues if the levels are not properly managed. Outdoor pools don't have these issues both because sunlight dramatically reduces the levels of those byproducts created in the first place and because they tend to just blow away.
    Aug 2007
    Eastern Canada
    54
    WikiAnswers says that an Olympic-sized pool holds around 650,000 gallons. PoolCalculator.com calculates that you would need 125 128 oz (US Gallon) jugs of Ultra bleach (6%) to bring such a pool to the 10 percent CL level that was used in Atlanta!
    18X36' 25000 gal Jacuzzi vinyl Inground Pool (1985) with resin sidewalls, newer Jacuzzi 1 hp two-speed pump and sand filter. Raypak propane heater, Rainbow 320 chlorinator (mostly use bleach).
    Softtub 220 portable hot tub.
    Apr 2010
    Coral Gables, FL
    197
    Thanks Jason
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Info for the London Olympic Pool:
    http://www.pwtag.org/researchdocs/Used% ... 0Devin.pdf
    3500 GPM each in the two large pools.
    Apr 2011
    Murrieta, CA
    2,360
    Waste from back washing will be used to flush toilets.
    Mar 2007
    San Rafael, CA USA
    12,082
    This link is about the construction of the Olympic Pool in London and how they focused on dampening waves.
