Results 1 to 14 of 14
Thread: Water in new pool off Level
    Hello- just filled my new 24 foot round 52 inch AG that was put in 4 days ago and the water is off level by 1 and 1/2 inches from one point on one side of the pool to another point directly opposite. At other points around the pool it is not off by that much although it is not perfectly level. Do I need to relevel the pool or give it some time and keep a close eye on it? Thank you.
    eebee65
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Water in new pool off Level
    Is this an intex style, or a traditional agp style?
    I think 1 inch is the max for most agp pool manufacturers, and I would expect better than that. If you had it installed "professionally", seems like they did not do a good job and should fix it.
    linen edit: I am not finding a reference to the 1 inch, so I may be wrong on that...1.5 inch still seems like a lot if the pool was just installed.
    It is a traditional AGP. I installed it with the help of a friend. Is there a way to get it level/more level without having to drain and start over? Thanks again.
    eebee65
    Sep 2011
    Omaha, NE
    95
    I know on my pool, it stated in big letters not to be off by more that an inch from one side to the other or pool failure could happen. There is NO WAY to relevel once it has been set, other than starting over. Leveling is the most critical part of the whole process.
    Do you have sand under your liner? Are your post set on patio blocks?
    16X24 Oval Doughboy
    10,000 Gallons~
    Pentair Dynamo .75/1.0 HP pump
    16" Pooline D-400 Sand Filter w/ 6-way valve
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Personally I think you're good if you are off at most 1 and one half inches (if this is a temporary pool that will be taken down each year). That is only 1 of the little squares on the liner. I've seen lots of pools out of level more than that. But that's just me. I think it's safe and I don't think you have any worry of collapse. What are the legs resting on. What I did to a friends pool was the following (he was out a little over 2 inches):
    His legs were resting on pieces of 3/4 inch plywood (which I would recommend over pavers on a temporary pool) which were resting on sand. We jacked up legs a little in some places, and in other places I used a hose to wash the sand from under the boards bit by bit until the legs settled to a relatively level position. I got VERY VERY close this way. Jacking up is scary but it can be done. One thing to watch out for is MAKE SURE YOU DO NOT PUT YOUR FINGERS OR HANDS UNDER THE BOARDS THAT YOU'RE WASHING SAND OUT FROM UNDER. IF THEY SETTLE YOU ARE IN FOR A BIT OF PAIN OR BROKEN BONES!! Of course this will only work if your legs are on sand or some washable material. If some people post and recommend against this method, then I won't argue. It's just something that worked for me.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Yes, sand under liner and it is set on 16 concrete blocks-It is a traditional AGP.
    eebee65
    Sep 2011
    Omaha, NE
    95
    If your post are ok, level from one side to the other, then you should only have to redo the sand. The best way to determine this is to use a laser level, can be rented and most rental stores and easiest to use at night. You can use it during the day if you have a story pole and laser receiver also, I just like how I can mark a 2X2 and then go to the other side of the pool to see if the post match up, or at least close.
    If it is your post being not level, I would be very leery of the stability of it. You get a bunch of kids in there and they start surging the water, you may have a big problem.
    16X24 Oval Doughboy
    10,000 Gallons~
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    1. The water is level, the pool isn't
    2. 1.5" is more than the industry average of 1" and thus most pool manufacturers would say you are beyond their recommendation (ie: warranty). Some people here feel that 2" is truly the limit - not that I'm advancing that opinion myself.
    3. The only way to level, if its a steel walled pool and not an Intex, is to drain it and level everything properly.
    Most posters with this problem are usually looking for someone to tell them it's ok to leave it up - that's your call. Be aware that your pool has something like 100,000 pounds of water and if it fails there is potential for property damage and/or injury - especially if there's kids around.
    At minimum you need to monitor it, if it continues to get worse it needs to be fixed to avoid total failure.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Cramer's right on with his advice.
    Was the pool level before filling it (i.e. were the pavers level...this is very important)?
    If they were then you have settling and it may settle more.
    Where the pavers were placed, did you dig down to your lowest undisturbed ground?
    Jul 2011
    844
    Have we determined yet if this is an Intex type or steel-walled pool? Permanent or temporary?
    Bestway SWG
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by GreatCanadian
    Permanent:
    Quote Originally Posted by eebee65
    eebee65
    It is a permanent steel-walled pool- a Fijian 24 round and 52"inches high. Yes the pavers were leveled and placed as low as we could go. I think that linen is correct. I think I may have settling at one side of the pool. Nobody is going in the pool until I get it leveled up.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I think this is a good idea. With a new liner, keeping it wet (in a big barrel or small pool) should keep it pliable enough to reinstall.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    Nice model pool.
    What kind of soil do you have, maybe some pics will help others give some advice.
