Thread: Paver Patio
    Guest
    Paver Patio
    We have pavers around our inground pool. My husband this spring had to re-level areas around the pool the ones that were sunken or popping up. When it rains we tend to get alot of sand in the bottom of our pool, and because our pool is so crystal clear using the BBB method, it is very noticeable. Is there anything we can put over the pavers, to keep all the debris from getting in the pool. THanks for any suggestions. Here is a pic of the pavers.[attachment=0:3a3ed3ml]pool.jpg[/attachment:3a3ed3ml]
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    Re: Paver Patio
    Once he resets the pavers, make sure he puts actually paver sand in the cracks. Then you can seal them with sealer. It helps them lock in place & the sand from shifting. Keep in mind this works best when the pavers are properly installed, 4-6 inch base highly compacted. Don't do as a "professional" hired by one of my clients to set pavers and tamp so much they shifted a return pipe and lowered it 4 inches and it broke.
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
