Thread: Drain and Refill Done
    Jul 2012
    Riverside, CA
    51
    I drained 75% of the pool water to lower CYA and CH.
    Before:
    FC: 0
    CC: 0
    TC: 0
    pH: 7.4
    TA: 130
    CH: 600
    CYA: 130
    Water is clear. Scaling with yellow algae imbedded.
    Tap water:
    pH: 7.5
    TA: 200
    CH: 200
    After replacing 75% water:
    FC: 3
    CC: 0.2
    pH: 7.7
    TA: 170
    CH: 290
    CYA:40
    Water is clear. Yellow algae still present, but seems reduced much.
    Actions:
    added dry acid to reduce the pH. (target 7.4)
    added chlorine to shock level. (target 15)
    Leave the fountain on to aerate.
    Leave the pump on.
    Will brush once a day.
    Am I on the right track? Thanks everyone for your inputs.
    20,000 gallons, IG plaster, probably built in the 80's.
    Filter: Hayward Pro-Grid DE6020, 120 GPM.
    Pump: Magnetek century E-plus, Purex Triton Whisperflow, WFE-4C, 1HP.
    Fountain booster: Century Centurion A O Smith, CAT B848, 1HP.
    Spa booster: G.E. Jacuzzi pump
    Heater: Raypak RP2100 Digital, Low Nox
    Feb 2008
    Denton, TX
    5,061
    Re: Drain and Refill Done
    Yes. Although I would add that if you are testing your chlorine levels using a 25 ml sample, you would be best served switching to the 10 ml sample as it saves you reagent. There really isn't a need to have accuracy down to 0.2 ppm. 0.5 ppm increments will always suffice.
    Jul 2012
    Riverside, CA
    51
    Quote Originally Posted by 257WbyMag
    Good tip. Thank you!
