Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: New pool owner, advice please!
    Jul 2012
    Sandpoint, ID
    18
    Hi Everyone,
    Thanks for such a great resource, I have found the information here amazing! I have never owned a pool before and just had one completed a couple of weeks ago and have decided to go the BBB route.
    Water has been in the pool for 15 days. Pool has been getting a couple hours of use each day by 4-8 happy people. Pool is about 725sf with 7 hours direct sunlight per day. 650sf heliocol solar heat on the roof is being used each day to keep the pool at ~88 and the spa at ~100. I do get aeration from water features (bubblers, deck jets, spa w/spillover and waterfall) that get usage probably an hour a day.
    The pool company included chemical service for the first 30 days. The pool guy told me he added 10-12 pounds CYA in the skimmer two weeks ago. Two days ago my water was starting to get cloudy, yesterday it was getting worse. This is when I decided to test the water myself for the first time and found no chlorine. So yesterday I added 9 quarts 6% in the morning. Afternoon FC measured 3, was still cloudy so I added 9qts more 6%. Late afternoon FC was at 5 (where I think I want it, you tell me). In the early evening I measured FC of 3, and again early this morning FC of 3 and water is mostly clear. Yay!
    Measurements from this morning using K-2006:
    FC 3
    CC 0
    pH 8
    TA 60
    CH 100
    CYA 40
    So I read Pool School but just have some questions before I start adding more stuff to the pool to make sure I am doing it right, all this pool stuff is new to me.
    I think I need to do the following according to the Pool Calculator:
    1. Daily - Add liquid Chlorine to get FC back to 5
    2. Add 30oz muriatic acid to get PH from 8 to 7.5
    3. Add 42 pounds calcium chloride to get CH from 100 to 250
    Does that sounds right? Should I throw it all in at once and then measure everything again or add one at a time? If one at a time, which one should I do first? Over 40 pounds of calcium chloride sounds like a lot, should I do maybe 10 pounds at a time and re-test the water?
    Thanks!
    16k Gallon IG Plaster 10x60 Lap Pool, Swimquip 1HP Pump, Swimquip HRP-24 Sand Filter, EUS PH 501 Heat Pump, Raypak SPA-PAK 3 Electric Heater, TF-100 Test Kit
    Christian's Avatar
    Jul 2012
    Sacramento, California
    304
    Re: New pool owner, advice please!
    Sounds like you're off to a good start. One thing I would always recommend is add less than what you think you need, re-test and work your way up. It's always easier to add more than it is to undo it! I would recommend adding 50% of what you need, testing, than another 25% and testing and then the last 25% if needed.
    Aug 2010
    Dallas, TX
    4,052
    I'd add make sure you have more MA on hand than you think you need. You may be well over 8.0, but not able to measure above 8.0.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, jimmyjoe
    Once you get your ph down, remeasure you TA and adjust up to 70-80 ppm with baking soda.
    After adjusting ph and TA...then:
    Cloudy water is almost always a sign of algae. I would start the shocking process even with your positive OCLT, and redo the OCLT tonight at shock levels.
    Hold off on the calcium chloride (and other stuff) until you are done with the shocking process.
    Christian's Avatar
    Jul 2012
    304
    Good point Linen.
    Jul 2012
    Sandpoint, ID
    18
    Thanks for the advice. I am working on getting the PH balanced first. I added 3 cups of muriatic acid, waited a little over an hour and tested PH went from 8 to 7.7. So I just added another 2 cups of muriatic acid to hopefully bring PH to 7.5. How long do I need to wait before I test the PH again? I have my filter pump running as well as my waterfall pump (waterfall is off, it's running to a 2" bypass in the deep end that gets a good current going through the middle of the pool). Thanks!
    May 2011
    Clearwater, FL.
    446
    Hi jimmyjoe and welcome to TFP!
    pH,
    With really good flow/circulation with the pump running, 2 hours should be fine, overnight would be better.
    Chuck
    Swim n Play 21' round, expandable 72" liner, 6FT deep center, buried 14", 12,750 Gallons
    Waterway 1HP-2 speed with 22" Sand filter
    TF-100 test kit
    Thanks to TFP my pool is perfect all the time :party:
    I now suffer from Sparklypoolitis! :whoot:
    I am a Platinum contributor because I want everyone who comes here to Trouble Free Pool to have the same success that I enjoy with my pool and family.
    Jul 2012
    Sandpoint, ID
    18
    PH 7.5
    TA 60
    Off to add some baking soda to get TA to 70-80
    Jul 2012
    Sandpoint, ID
    18
    After baking soda:
    TA 80
    Last night:
    FC 15
    CC .5
    This morning before sun hit the water:
    FC 10.5
    CC 0
    Clear sparkling water
    So I lost 4.5 FC overnight. I brushed the pool this morning and I'll keep adding chlorine to keep FC at ~16 today and see what happens tonight.
    Since I am learning, I went ahead and tested PH and TA this morning as well. PH 8 and TA 90. Did these increase as a result of shocking the pool? Just curious. Should I not really worry about the increase in PH until the shock is complete? Thanks!
    -James
    Jul 2012
    Sandpoint, ID
    18
    Adding a bunch of chlorine... Please let me know if this looks reasonable or if you suggest I do something differently. Shock target is FC 16. Thanks!
    @7:30 FC 10.5 (no Sun) -> Added 1.3 Gallons 12.5%
    @8:30 FC 13.5 (1/2 Sun) -> Added 1 Gallon 12.5%
    @9:30 FC 14.0 (Full Sun) -> Added 1 Gallon 12.5%
    @11:00 FC 11.5 (Full Sun) -> Added 2 Gallons 12.5%
    Need to go get more!
    -James
    Aug 2010
    Dallas, TX
    4,052
    pH readings can be off with high FC levels. If your water features are running, they will drive up pH.
    Jul 2012
    Sandpoint, ID
    18
    Added a total of 12 gallons of 12.5% yesterday. Lost 2 FC last night, better than 4.5 the night before. Brushed the pool again this morning and will be going back to the store to get another 12 gallons. Hopefully will lose less that 1 FC tonight!
    Looking forward to a safe refreshing pool for my family, the kids are getting impatient and want to swim. Who am I kidding, so am I!!! I tell them it was the pool guys fault... who was subcontracted for 30 days by the company that built the pool. Even though the chemicals and service were "included" I told him on Monday (after 15 days) not to come back to my house. In hindsight, I wish I would have searched and found this site and learned about BBB before putting water in my pool and just started doing it myself from day 1.
    -James
    R.J.'s Avatar
    Jul 2012
    Minneapolis
    82
    Keep it up, James. It's a good feeling taking control of your pool. Soon, you'll be the one giving advice!
    18 x 48 Intex Ultra Frame
    2500 gph cartridge filter
    Intex SWG
    Jul 2012
    Sandpoint, ID
    18
    Added another 12 gallons of 12.5% yesterday. Last night I lost 0 FC and CC is < .5
    YAY! It does feel good taking control of the pool and knowing it will be done right. Thanks for everyone's help!
    Off to add 1/2 of my calcium chloride
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Do you have any lights or other hidden places. You are doing great but it seems like you are losing a lot of FC at night.
    Keep it up!
    -- Guy --
    Jul 2012
    Sandpoint, ID
    18
    Quote Originally Posted by techguy
    Keep it up!
    My shock is done, passed all 3 tests this morning. WOOHOO! I do have LED lights in the pool. What do you mean by other hidden places?
    Mon: Lost 4.5 FC
    Tue: Lost 2 FC
    Wed: Lost 0 FC
    Christian's Avatar
    Jul 2012
    304
    I think what techguy means is any nooks, crannies or crevices where algae could be hiding and you can't actually see it. Algae gets hidden in spots like that and can be tough to get rid of because you don't even realize it's there.
    Jul 2012
    Sandpoint, ID
    18
    Gotcha, that makes sense. Thanks
    After adding 20 pounds calcium chloride:
    FC 12.5
    CC 0
    PH 8
    TA 90
    CH 180
    Going to add 20 pounds more calcium chloride and once the FC comes back into normal range, test and adjust PH if necessary.
    -James
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Kudos! Welcome, and enjoy your trouble free pool
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
  20. Back To Top    #20
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Boy! The locals are taking over Joe. Christian and myself are your neighbors.
    As was mentioned above, many people get close but they have something growing behind the light or in the backside of the ladder. It might be worth taking out your light for 10 minutes and cleaning behind it, just so you don't have any surprises next week.
    -- Guy --
