Results 1 to 20 of 20
Thread: new here, want to start BBB
    Jul 2012
    Staten Island, NY
    10
    Hello!
    Wish I heard about BBB when we installed our AG in June! Want to switch from trichlor tabs to BBB!
    My TF-100 results:
    FC - 8
    CC - 1
    PH - 7.2
    TA - 80
    CH - 50
    CYA - 50
    Any advice would be appreciated!
    Morada RTR Supreme AG Pool, Oval 12'x17'x54" 5,400 gallons, Pentair CC75 Cartridge Filter w/1 HP Pump, installed 6/22/12, TF-100, BBB
    30,419
    Re: new here, want to start BBB
    YOur numbers aren't bad....what does your water look like?
    Jul 2012
    Staten Island, NY
    10
    water is clear
    frogabog's Avatar
    Jul 2010
    Portland, Oregon
    1,578
    1ppm CC is fairly suspect however. No?
    Where kids swim in 54 degree water, turn blue, and giggle happily cuz they got a POOL!
    Year 3 BBB -15' x 48" Intex Metal Frame - Was using (2) 1000gph Intex cartridge filters (see Full time pumping Intex). 2012, converted to 1600gph and sand filter+SWG = Sand filter love affair!
    Don't waste time and energy looking for a better value on test kits, the TF100 is the best deal around. I did the looking and spent the extra money, but you don't have to make the same mistake. Just go here: TFTestkits. I use Pool Calculator for min/max, and shocking chlorine levels.
    Feb 2008
    Denton, TX
    5,061
    Well, if you do have a CC of 1, a quick shock is probably in order. That would be what I would do anyway.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Welcome to tfp, Liz91899
    I agree with the others, CC of 1 ppm means you have organics in the pool, and you need to do the shocking process.
    30,419
    While a CC of 1ppm is not good, you could actually give it another day of testing before you start the shock process.
    Since your water is clear, I would just elevate the chlorine up to about 20ppm tonight and then check your CC's in the morning.
    If it has dropped to .5ppm or less, there is no need to shock and you can let FC drift back down to normal.
    Jul 2012
    Staten Island, NY
    10
    Tested again
    FC - 10
    CC - 1
    PH - 7.2
    TA - 80
    CH - 50
    CYA - 50
    My CC is still at 1. How slowly do I pour the bleach in the pool this evening? Thanks for all the replies.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by Liz91899
    Tested again
    FC - 10
    CC - 1
    PH - 7.2
    TA - 80
    CH - 50
    CYA - 50
    Slow enough that it doesn't splash, do it right in front of the return and you should see the cloud spread out and disperse.
    Jul 2012
    Staten Island, NY
    10
    How long do I run the filter? Thanks
    Richard320's Avatar
    Jan 2010
    18,995
    Generally, it's recommended you run the pump for half an hour after adding chemicals to let them mix. However, since you're performing essentially an abbreviated shock process, I'd let it run all night. If it's too noisy or whatever, run it as long as you can, and get in there with a brush to be sure it's totally mixed, no dead spots in the circulation.
    Have you read ?
    Jul 2012
    Staten Island, NY
    10
    Thank you, Richard Yes, I read pool school.
    30,419
    The sun will be quite helpful tomorrow in burning off the CC's so I hope you get sun, and if so, test later in the day giving the sun a chance to work.
    I've been walking around my pool with Bleach (other times Borax...) and adding maybe 1/6 of container in front of each jet. So it takes me maybe 2 minutes to empty a container then rinse. Some at each jet waiting just a bit between. Does this sound like a good way to continue adding chemicals when needed?
    DARaynor - weaning off Leslie's poor service & high prices, too many chems!
    AG ~24,500 gal custom shaped, small waterfall directly into pool, gunite/pebbletech/plaster, Oazonator Ultra Pure set on medium,
    cartridge filter (cleaned monthly), Pump (8 hours/day) w/chrlor tabs inline, also use Chlorine liquid,
    Polaris 380 (3 hours/day), empty skim baskets & brush steps/deck & where cleaner can't reach daily.
    Jul 2012
    Staten Island, NY
    10
    My TF-100 today results:
    FC - 14
    CC - .5
    PH - 7.5
    TA - 90
    CH - 50
    CYA - 50
    I raised my FC to 20 Monday night to lower my CC: 1. Didn't test yesterday, the weather was cloudy with some sun. Is it safe for the kids to swim in it today with the FC at 14?
    Richard320's Avatar
    Jan 2010
    18,995
    FC - 14
    CC - .5
    PH - 7.5
    TA - 90
    CH - 50
    CYA - 50
    The water is clear? Then, yes, because FC is below shock level.
    You really ought to run the overnight loss test to be sure it's all dead. Because if it isn't, you're still soooo close it would be a shame to not deliver the death blow.
    Jul 2012
    Staten Island, NY
    10
    Water is very clear. Should I shock it because my CC is 0.5 or just do the overnight test?
    Richard320's Avatar
    Jan 2010
    18,995
    Sigh....
    I thought you were undertaking the shock process? If not, then why do you have such high FC?
    The three tests to know when you're done with the shock process:
    CC is 0.5 or lower;
    An overnight FC loss test shows a loss of 1.0 ppm or less;
    And the water is clear.
    You have two of the three for sure. All that's left is the overnight loss test. If that passes, you can let FC drift down to normal levels.
    FC - 2.5 + CC - .5 = TC - 3
    PH - 7.1
    TA - 80
    CH - 420
    CYA - 70 I think, this is a hard one to be sure...
    Water is perhaps 85% clear (been clearing every day since I started attempting BBB). Filter cleaned Sunday, showing good.
    So I am thinking add a little chlorine via bleach, then a little Borax to raise PH to optimal.
    How are the other numbers and advice? Brushing every day. Not much of anything anywhere except dust on shallow deck where pool cleaner does not go.
    Thanks.
  20. Back To Top    #20
    Jul 2012
    Staten Island, NY
    10
    Richard, I misunderstood when 257wbymag suggested a quick shock. I thought a quick shock is just to raise my FC to 20 with one bleach application. I also thought my CC needed to be at 0.
    My other problem is we are going away Thursday-Sunday. Do I throw a couple of pucks in the floater or have my neighbour put in bleach?
