Thread: Test Kit and Optional Items
    Hi TFP Warriors,
    I have been fighting with my SWG pool for years. It has aways been a little cloudy but yesterday I noticed the water had a sour/algae smell to it. The water also felt dry and it burned my skin a little. I am going to purchase the TF-100 so I can try the BBB method but I noticed their website have a few other optional items. My question is, what else do I need other than the TF-100 kit? I want to make sure I have all the calculations needed for the recommended pool calculator website.
    Thanks for your time.
    Reese
    10k gallons, STA RITE - PXC125 cartridge filter (50 psi), inground plaster kidney-shape, Jandy AquaPure (APURE700) SWG - Miami, FL
    Apr 2012
    SW Ohio
    456
    Re: Test Kit and Optional Items
    you might want to get the xl option it will give you alot more reagent to do more tests........welcome to the BBB family and TFP......you won't be sorry.......Mike
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
    Apr 2012
    SW Ohio
    456
    when you get the test kits post a complete set of test results so we may assist you with any questions you may have, also if you havent already read pool school it is in the top right of every page.....Mike
    I suggest adding the SpeedStir and maybe salt tests. You might order extra CYA tests and extra chlorine tests, I went though a lot of those at the start.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Salt test strips, if you don't already have them.
    I'd urge you to spring for the XL option, because it sounds like you're going to be starting the shock process, and that burns through a lot of the FAS-DPD reagents.
    Nobody who has bought a speedstir has posted any regrets
