Results 1 to 10 of 10
Thread: Safety Cover (18x36 rectangle)
    Feb 2012
    Winston Salem NC
    161
    I am looking for opinions / recomendations on Safety Covers. My pool is 18x36 with steps on the shallow end.
    What size do I buy? When I see an 18x36 cover, is it for an 18x36 pool, or is that the actual dimensions of the cover.
    What brand?
    Solid vs Mesh? I am thinking solid, but if I were an expert then i wouldnt be asking....
    Any links to them would be appreciated....
    Thanks
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Safety Cover (18x36 rectangle)
    Safety covers are custom made to your pool measurements.
    Feb 2012
    Winston Salem NC
    161
    I guess safety cover is not the correct term. I am looking for a cover for winter. One that stretches tight over the pool and anchors into the concrete.
    Ideas?
    Tigershark QC Robot
    SW Indiana
    9,199
    Quote Originally Posted by head gamez
    Ideas?
    That is a safety cover. Loop-Loc is the most well-known brand. They are custom made to a drawing of your pool. Check out http://www.poolcenter.com/looploc.htm for details on what the choices are.
    A solid cover requires a pump, but you can get solid covers with a mesh panel to drain the cover or very fine mesh that reduces dirt getting into the pool. Solid covers reduce algae growth when the cover is on. I have a standard mesh, and I don't see any real advantage to the solid other than the algae issue, but even that isn't a big deal unless you need to open your pool later in the year.
    Qwaxalot's Avatar
    Jun 2012
    439
    If your pool is truly a rectangle, the deck and coping flat, and nothing intruding below coping, you can buy a ready made safety cover. The cover needs to be two feet longer and two feet wider than the pool.
    You can go to various manufacturer's web sites for detailed information.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Feb 2012
    Winston Salem NC
    161
    What is everyone's opinion on Solid vs Mesh?
    Tigershark QC Robot
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I like loop-loc's ultra loc. It's solid with mesh drain panels so it stays algae free and doesn't require a pump.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Nov 2011
    Moberly,MO
    1,010
    I have tried the ultra mesh and won't ever have anything but a true solid cover with a pump to remove water from the cover.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Feb 2012
    Winston Salem NC
    161
    From what I can gather, I will need to custome order a cover because I have 4' radius "corners". I was only able to find that information on poolsupplyworlds website (for a Merlin). Is that true for all brands?
    For whatever reason I seem to be struggling to find a cover with a pump. Does anyone have a link to a recommended one?
    Tigershark QC Robot
    Nov 2011
    Moberly,MO
    1,010
    Most companies would rather sell you a mesh cover so they can sell extra chemicals. Not sure that you will be able to buy direct from the manufacturers.
