Thread: whats the wait time after putting MA in pool to shock?
    Jul 2012
    Canton, Oklahoma
    5
    I am fighting algae. I am fighting high PH & TA. I have been brushing, vacuuming, adding MA (per the pool calculator info) to the pool several times today. I am wondering how long after the last dose of MA do I have to wait before I add bleach to shock?
    AG 7000 gallon, vinyl, Krytsal Clear saltwater system, krystal clear filter pump about 2000 gallons per hour. pool set up 7/15/2012.
    Jul 2009
    Olney, MD
    218
    Re: whats the wait time after putting MA in pool to shock?
    30 minutes with pump running and added in front of return (or less if you do some brushing in between as well). Just so long as it is pretty well mixed in.
    20k gal, IG Vinyl, IntelliFlo VF Pump, 60 GPM sand filter, Jandy Aquapure Ei 35, 2 skimmers, one main drain, two returns, Dolphin Diagnostic cleaning robot, Taylor K-2006 test kit
    UnderWaterVanya's Avatar
    Jun 2012
    Mint Hill, NC
    2,589
    Numbers?
    If you are fighting algae are you going through the shocking process detailed here? pool-school/shocking_your_pool
    If so your Free Chlorine is likely > 10 ppm which renders the pH test invalid. Either let FC drop to below 10 and check and adjust to around 7.2 and then start the shocking process again or ignore pH until you complete the process.
    30,419
    You shouldn't be doing both at once. Post some test results and we'll help you get your pool fixed.
