Details:
Gunite 25,000 gallons
Chlorine base w/waterfall (no heater)
Pump-Century Centurion, A.O. Smith, Serial No. BW6-01, Part 7-177476-20, Serial No. BW6-01, HZ-60, RPM-3450, Volts-230/115, Amps-11.2/22.4
The impeller will not spin at all. If it is supposed to move freely, it does not move at all. I have disassembled the motor, from the unit, but am unable to access the impeller. I am not able to remove the top of the motor to get to the impeller to see what the problem may be. I have removed all nuts and bolts from the motor, but am still not able to access the impeller.
Any help is appreciated.
