Results 1 to 7 of 7
Thread: Pool Pump Impeller Issues
    Details:
    Gunite 25,000 gallons
    Chlorine base w/waterfall (no heater)
    Pump-Century Centurion, A.O. Smith, Serial No. BW6-01, Part 7-177476-20, Serial No. BW6-01, HZ-60, RPM-3450, Volts-230/115, Amps-11.2/22.4
    The impeller will not spin at all. If it is supposed to move freely, it does not move at all. I have disassembled the motor, from the unit, but am unable to access the impeller. I am not able to remove the top of the motor to get to the impeller to see what the problem may be. I have removed all nuts and bolts from the motor, but am still not able to access the impeller.
    Any help is appreciated.
    Re: Pool Pump Impeller Issues
    The information you gave is from the motor, not the pump. If you can post the pump information, or a picture, then we can better advise you.
    Support the site
    Re: Impeller Issues
    I have modified my subject title. I am new to this, so forgive me if I do not put the "correct" wording. The impeller is the problem, which is attached to the motor, correct?
    Jul 2011
    Myrtle Beach, SC aka Redneck Riveria
    125
    The motor is the engine. The pump is the body it's attached to.
    What kind of pump is it? Manufacture? Is there a cap on the back middle of the motor that can be removed and expose the "axle" of the motor.
    Has the motor been working recently?
    "When your pool is sick, call the doctor, I make house calls"
    One stop pool shop, I do everything but install them. 9+ years of experience.
    The pool has been idle for 7 months and has not been in use. Prior to this, it was working fine. I will look for the other information.
    Jul 2011
    125
    It's very possible it has locked up. If you can gain access to the shaft from the back of the motor you might be able to "jump start" it. With the switch to the motor off. Take a crescent wrench, pliers, 1/2 or 9/16' open ended wrench and spin the shaft, turn it clockwise & counterclockwise. If it turns then you might be in luck. Flip the switch to the motor & see if it turns over. Auto Parts stores carry a lubricant for electric components. You can try spraying that around the impeller and the back where you access the shaft. WD40 is FLAMMABLE and should not be used on electric motors.
    22,551
    If you've removed all the bolts from the motor and the pump casing the casing will come apart. There's a seam where the casing halves come apart. You may have to pry it apart because it's been sitting but it will come apart.
